anyone know why our cranks arent keyed?
Old May 9, 2004 | 09:42 PM
will62085's Avatar
does anyone know why GM decided to not key our cranks for the harmonic ballancers?...ivebeen through two hubs and now a fluid damper, and cant get anything to keep from spinning on there...i guess its the crank...so back out with the motor...stupid on gm's part if u ask me
Old May 9, 2004 | 10:05 PM
Dave88LX's Avatar
My guess is they figured since the harmonic dampener had no balance there was no reason to key it...just a guess.
Is there a way for you to better press it on?
Old May 9, 2004 | 10:27 PM
Well, the crank is cut for a key. There is just not one in it. You can put one in there and use a keyed hub or dampner.
Old May 9, 2004 | 10:38 PM
bunker's Avatar
essentially a crank with no key would be stronger, but thats not why they didn't put a key in. Just cutting the crank for the woodruff key creates 90* stress risers, buy putting in a key its further creates the tendancy to crack. Like I said, I doubt thats why & plus that part of the crank only drives your accessories
Dunno just going on & on.
Old May 9, 2004 | 11:18 PM
Dave88LX's Avatar
How will that affect the balance?
Old May 9, 2004 | 11:53 PM
MyZb383's Avatar
I've never heard an expanation on this that made any sense to me. It just seems like a GM brain fart.
LT1 design committee's crankshaft "To Do List":
Step 1. Cut crank for key.
Step 2. Make hub with no key slot.
Step 3. Act normal. And hope the hub doesn't spin, or at least that nobody notices, if it does.
Old May 10, 2004 | 04:08 AM
Zepher's Avatar
Isn't the LT1 crank the same as normal SBC crank?
Old May 10, 2004 | 06:38 AM
Eff's Avatar
Eff
Mine does!
All you have to do is machine a slot in the hub and put a key in
Old May 10, 2004 | 07:42 AM
442olds's Avatar
crank hub
If you look at an aftermarket hub you'll notice that to make a keyed hub cheaply it has to be two parts. On a production line this usually isn't cost effective. the only way to correctlymachine a key slot is to use a broach which requires a hole the same diameter completely through the hub. But on the fatory hubs there is a large obstruction in the middle of the hub which the balancer bolt passes through and causes all sorts of problems when trying to use a standard balancer puller.
The aftermarget hubs actually bore out the front of the hub and then insert a second piece which acts like that washer face in the fatory hub. And this is done after the keyway broaching process. This is an extra step and when your trying to cut costs any extra machining steps you can cut out the better.
I bet the engineers wanted to put the keys in, but the penny pinchers told them to do without.
Old May 10, 2004 | 08:41 AM
There should be no effect on balance because it is really a dampner and not a balancer. There might be some exceptions were there is a small weight or two used in the holes in the pulley. In your case where you have a complete new rotating assy, you don't need to worry about it. Any replacement hub/pulley or aftermarket dampner should have neutral effect.
Old May 10, 2004 | 11:49 PM
will62085's Avatar
okay, so the new damper slipped and it ate up the end of the crank...so now i have to change the crank, is there a way to do that in the car? im thinking supporting the motor, dropping the k member, and doing it underneath...seems like it would work, but will i be able to get all the rods off and back on the crank without removing the heads??...hmm...this is very frustrating
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Knightscrapper
Feb 4, 2016 10:25 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
