anyone heard of this cam?
Old Mar 23, 2004 | 10:15 PM
93formula's Avatar
grind number lt1 3109/3112 hr114 +4
serial number l 7662
int .513 ex .510
duration 276 290
valve timing
at .050 int 0 btrdc
40 abdc
exh 52 bbdc 3-atdc
installed on a 110 intake centerline
duration at .050 int220 exh 229
lobe lift .3420 in .3400 exh
lobe sep 114
any ideas on how it will perform on stock heads and manifolds?
Old Mar 23, 2004 | 11:05 PM
Revis_Racing's Avatar
sounds very similiar to the Comp 220/230 cam
Old Mar 23, 2004 | 11:26 PM
93formula's Avatar
anyone have any results from that comp cam?
Old Mar 24, 2004 | 09:26 AM
Well, with a set of stage II ported heads that cam makes about 325-340rwhp. Its alot like the hotcam but with little wider lobe.
The cam does not have a very radical idle, but you can tell its an aftermarket cam. Lope from 1-10: 3 or 4
Cam pulls hard to 6200rpm.
Old Mar 24, 2004 | 08:54 PM
93formula's Avatar
thank you!!
AdsoYo
May 2, 2018 03:21 AM
Klypto
Mar 23, 2016 09:05 AM
transam_388
Mar 15, 2015 11:53 AM
StansZ28
Feb 19, 2015 07:39 AM
