Anyone have a writeup on altering stock vavle covers for 1.6 pro mags?
Old Sep 12, 2004 | 07:00 PM
trans9_5am's Avatar
Just what the title says. Need to alter the inside of the covers because they hit the rocker arms. I need a write-up or a short detailed description to help perform this task. Any help is better than none. Thanks in advance.
Brandon
Old Sep 12, 2004 | 07:20 PM
disco192's Avatar
Re: Anyone have a writeup on altering stock vavle covers for 1.6 pro mags?
If you look at the underside of the valve covers, you will see metal strips with a lip that help support the bolt holes. On the manifold side of the valve covers, you will need to bend those lips with some pliers so it will slide in between the rocker arm bases.
It should take 2 minutes. Just look for a metal piece that slides inbetween the rocker arms and bend the metal flat.
Old Sep 12, 2004 | 07:23 PM
trans9_5am's Avatar
Cool. Sounds easy enough. Ill let you know how it goes.
Thanks,
Brandon
Old Sep 12, 2004 | 11:22 PM
lillbush5555's Avatar
I just cut the middle pieces out You can use a dremel or the best I have heard (Xxsaint69X) Used his moms pruning shears
Matt
Old Sep 12, 2004 | 11:26 PM
LJ93Z28GM's Avatar
Ultimate ghetto but practical is to just set a pair of vice grips on the center supports and wiggle back and forth till they break out they are just spot welded in there.
The ribbing molded into the top of the valve covers makes them strong enough that they are not needed.
Also you can just force them past the rockers and they will still clear.
Seen both ways done and both worked
Old Sep 13, 2004 | 12:03 AM
atljar's Avatar
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Your welcome
Old Sep 13, 2004 | 12:06 AM
I was wondering..If I dont have the supports in the center of my valve cover do I still need the narrow body rocker arms? Or can I use standerd RR?
Matt
Old Sep 13, 2004 | 11:19 AM
trans9_5am's Avatar
Sweet... Thanks everyone.
Brandon
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
