Anyone have problems putting on timing chain?
Old Apr 23, 2003 | 10:24 PM
All_Z_Way's Avatar
Question Anyone have problems putting on timing chain?
I was having problems tonight putting on a new timing chain and new upper cam sprocket.
When ever I got the chain and sprocket on the dots wouldn't be lined up properly. When the dots were lined up, then I couldn't get the sprocket on the dowel pin.
Any ideas?
Old Apr 23, 2003 | 10:31 PM
You just have to line it up and play with it. You will eventually get it to go on. Double check the dots when you finally get it on. You can try rotating the cam CW a little, so the dowel is closer. Slip the cam gear on the dowel and then push up to rotate the cam CCW back in the right place. Have your bolts handy to start threading in.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
