Anyone have a PN for crank key?
Old Mar 24, 2005 | 06:34 PM
Myxtreme1's Avatar
I can't find the one that came out of mine so I am just going to buy a new one. If anyone could hook me up with the PN it would make it way easier at the dealership. Thanks!
Old Mar 24, 2005 | 06:38 PM
30696bird's Avatar
Re: Anyone have a PN for crank key?
We don't have crank keys.................it has 3 bolts offcentered to hold on the homonic ballancer.
Old Mar 24, 2005 | 06:59 PM
Yes, there are crank keys (for the crank gear).
93-95 GM PART # 10128303
96-97 GM PART # 12550096
Old Mar 24, 2005 | 07:09 PM
trax's Avatar
How about if you get a crank hub machined for a key?
Old Mar 24, 2005 | 07:16 PM
Then you need an additional normal key.
Old Mar 24, 2005 | 10:18 PM
Myxtreme1's Avatar
Thanks!!
Old Mar 25, 2005 | 06:05 AM
30696bird's Avatar
Now don't I look like a complete dumbass I was not using my brain when I posted this.........sorry.
Old Mar 25, 2005 | 09:27 AM
Myxtreme1's Avatar
lol...I knew what ya meant.
Old Mar 26, 2005 | 09:20 AM
Myxtreme1's Avatar
So since there is no key for the hub, doesn't it slip pver time?
Old Mar 26, 2005 | 09:32 AM
30696bird's Avatar
The ballancer has 3 bolts (17 MM is what I used I think, might have been 3/4 ) They are offset so there is only one way it will go on. With the 3 bolts in there is NOWAY it can slip.
Old Mar 26, 2005 | 11:16 AM
Dave89IROC's Avatar
ummm........
he asked about the HUB, and no, it is tight enough that it does not slip
Old Mar 26, 2005 | 12:18 PM
You might want to quit while you are ahead..... the crank hub can slip on the crankshaft snout. Its a problem when people try and put a blower pulley on it. Common "fix" is to machine an additional keyway into the crank, and double-key the damper hub. Keying the hub to the crank is also recommended when using a crank trigger wheel (e.g. - Electromotive SDI/Opti Eliminator, may it rest in peace), to prevent slippage from altering the timing. Electromotive's test showed that LT1 engines with as little as 350-400HP could experience slip.
"homonic" balancer???
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Knightscrapper
Feb 4, 2016 10:25 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
