Anyone have pics of true duals out the back?
Old Jan 7, 2006 | 01:04 AM
HardcoreRM125's Avatar
So, I think the next mod I will be saving for is to convert to true duals. I plan to build the motor, and every bit helps, so I mind as well get rid of my flowmaster catback set up. However
Anyone have good pics of their true duel set up? Or even a very detailed explanation?
Id like to know diameter piping, and ground clearance, and how you route past the rear end? I cant part with two tail pipes out the back. It just doesnt look right on a 4th gen. Also, any suggestions for muffler placement?
I was going to try and somehow fit the biggest dual exhaust I can past the rear, and out the back, with two flow master 40's on it cause they just sound wicked. And they happen to be unrestrictive.
Old Jan 7, 2006 | 06:28 AM
HiTech5's Avatar
Re: Anyone have pics of true duals out the back?
Check thirdgen.org in the exhaust section. Alot of good ideas there.
Old Jan 7, 2006 | 11:48 PM
Anyone?
Old Jan 8, 2006 | 01:37 PM
6SpdLT1Z's Avatar
I'd like to see pics as well.
Old Jan 8, 2006 | 03:11 PM
klpps's Avatar
Here are some OK pics off my 97 camaro.
http://www.shenger.net/camaro/true_duals/
I've since replaced the can mufflers with dual/dual tips. The car is lowered with an eibach pro kit. I have no clearance issues.
If you plan on putting on true duals I have a new magnaflow muffler w/ a built in x-pipe in its core, made specifically for true duals. Here is some info.
http://www.magnaflow.com/02product/s...ne=main&id=437
125$ shipped.
Jan 23, 2015 01:13 PM
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
