Anyone have the part number for the optical part of the optispark?
Old Jan 16, 2005 | 06:38 PM
fesgali's Avatar
Anyone have the part number for the cam part of the optispark?
Not the cap/rotor or the whole thing. Just the optical/cam thing.
Old Jan 16, 2005 | 06:45 PM
Re: Anyone have the part number for the cam part of the optispark?
GM does not sell it, AFAIK. Don't know if any aftermarket suppliers do.
Old Jan 16, 2005 | 06:48 PM
fesgali's Avatar
Hmm...is there a way to visually see if the one that i have (optical/cam thing) has gone bad?
Old Jan 16, 2005 | 06:56 PM
FastKitteN's Avatar
Not really.
It's also not a GM part, it's a mitsubishi
-Shannon
Old Jan 16, 2005 | 06:57 PM
I doubt it, unless it looks burnt up or something. The optical portion does not seem to be a weak point. Bearings, cap and rotor are the real wear items.
Old Jan 16, 2005 | 09:06 PM
ramermanz28's Avatar
Re: Anyone have the part number for the optical part of the optispark?
Are you throwing any codes? If the optical portion is bad you'll get a code 36(hi-res failure) or you may also get a code 42(est grounded). You can see my post in the Forced induction section titled "attention Vortech owners" where I talk about some of these problems.
Old Jan 17, 2005 | 11:55 AM
fesgali's Avatar
Well i did throw a code with a hard start the last time i started the car. And i don't have any scanning software to check the code.
Old Jan 17, 2005 | 12:13 PM
hsyr's Avatar
Take it to your local GM dealer they can pull the codes for you. They do it for free for me all the time.
Old Jan 17, 2005 | 12:23 PM
fesgali's Avatar
The car is missing a wp right now so it's not gonna be goin anywhere.
Old Jan 17, 2005 | 12:30 PM
Tom Piper's Avatar
The ECM supplies a regulated +5 volts to one pin of the Mitsubishi optical device.
There are two sensors in the one optical device -- there are two sets of "slots" in the optical wheel, one for high-res and one for low-res.
You can monitor the output pins of the optical device with an oscilloscope and see the pulses. I've done bench tests this way to prove the device is functional while turning the shaft by hand.
You can determine which cylinder is in the firing position by determining how many high-res pulses are in a low-res time frame.
Tom Piper
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
