Anyone have OTVC wires and TC?
Old Nov 1, 2007 | 11:52 AM
White96Z28's Avatar
I've got a 96 Z28 with traction control that I am going to run an OTVC kit on. Has anyone done this and managed to get it to look halfway decent? The Traction Control module on the driver's side valve cover sits right in the way of the wires and on top of one of the valve cover bolts. What's the best way to get around this without going the shadetree mechanic route and using zip-ties instead of the last wire loom? I'm thinking I may try to space the TC module so that there's room to run the wires underneath it, but I don't know that I have the hood clearance to do that. Any opinions?
Old Nov 1, 2007 | 02:13 PM
BradZ28's Avatar
Mine fit under there just fine.......maybe bend the bracket some?
Old Nov 1, 2007 | 02:20 PM
SS MPSTR's Avatar
Mine fit too with a little work.
Old Nov 1, 2007 | 02:26 PM
dangalla's Avatar
mine fit just fine
TAEnvy's Avatar
Make sure the bracket is bolted down tightly, I tried to get some under it and noticed it was loose and I tightened it back up and there is plent of room now.
Old Nov 1, 2007 | 03:09 PM
White96Z28's Avatar
I may have to play with it a little bit then. It sits right on the valve cover on mine...
Old Nov 1, 2007 | 04:02 PM
deadtrend1's Avatar
yea, I had no clearance issues with mine at all
Old Nov 1, 2007 | 04:25 PM
urbaNHunter44's Avatar
mine fit perfect, just bend the tc bracket a little, or delete it together
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
