anyone have any pics????
Re: anyone have any pics????
If you search for it, there will be lots and lots of threads that come up. Its been discussed lots of times, and most people who do it have pictures posted in their threads. So just search for it, and take a peak at a few, im guessing if you look at five, there will be on with pictures. To my knowledge, you cant run true duals like mustangs, trucks, where you go over the axle on both sides. You have to run it along the original exhaust lines and then have them go their seperate ways in the rear (if you wasnt aware of this)
EDIT:
Sorry i thought of something else.
Some people are going to say that three inch is over doing it for n/a 350. Im not for sure what your set up is since you dont have a signature but you may want to look into 2.5" pipe since it will be a tight squeeze running the two pieces side by side along the stock exhaust layout. Yes some have done the 3'', but it may or may not be worth it to you. Just my opinions, but who the hell am I?
EDIT:
I also thought of dumping the exhaust in front of the rear tires instead of going over the axle. I haven't herd of anyone doing that. I was also wondering what that would look like. Do you think I would have enough clearance?
For an over the axle setup, BMR makes a panhard rod upper brace relocation kit that opens up room on the left side:
http://www.bmrfabrication.com/F-body...tm#panhardrods
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cmsmith
Jul 10, 2015 07:19 PM
