Anyone had a solid roller Nitrous cam ground?
Old Oct 16, 2010 | 07:00 PM
walt355's Avatar
Getting back on my car, again. I talked to Cam motions last year and they told me that I would have to have a custom core made for a solid roller with a nitrous grind on it. anyone else know this?
thanks
Old Oct 16, 2010 | 10:19 PM
red94chicken's Avatar
what is your question?
Old Oct 17, 2010 | 08:31 AM
walt355's Avatar
Do you have to have a custom core for a SR Nitrous grind cam? If not who do I talk to?
Old Oct 17, 2010 | 08:47 AM
Also not clear what you want. The shop that built my engine spec'd a solid roller nitrous cam, and had it ground by Comp Cams. Nothing special that I am aware of, and the cost was no different than any other cam.
Old Oct 17, 2010 | 12:57 PM
are you talking about what the cam is made out of?
Old Oct 17, 2010 | 08:47 PM
walt355's Avatar
Yeah, Cams have to start with a core to be ground. According to the guy I talked to a Solid roller cam for a Lt1 would have to have a custom core made, not a shelf core, for a nitrous grind. He said the core by itself would be around 300 and another 200 or so for the grind. Maybey he didnt know what he was talking about. Like I said I called Cam motions
Old Oct 17, 2010 | 08:53 PM
Why would a cam for a nitrous application have any different properties than a cam for an NA or forced induction operation?
A solid roller cam will experience higher valve train loadings than a hydraulic cam, so maybe there's an issue with the strength of the core, but solid rollers are so common, I doubt that any competent cam company would not know how to build one from one of their stock cores.
Old Oct 17, 2010 | 08:56 PM
walt355's Avatar
LSA was one factor if I remember right. and also he was talking about the cut for the retainer plate being another as on the LT1 cam
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
