Anyone had heads ported by Lloyd Elliot?
I am seriosly considering having Lloyd Elliot port my heads. (LE2 head package)
Have any of you had your heads ported by Lloyd?
What flow bench numbers did you see, if you had them flow tested?
What combinations are you guys running with his heads? (355? 383? CC306cam? LE1 cam? etc. etc. etc.)
What dyno numbers did you see?
A big thanks in advance!
i just maild my heads off to him Friday
my friend JONEZZ also has had his heads done by Lloyd. no dyno results yet from either of us, my rebuild is curently underway with a 383 should make 400 to the ground. my friends 350 with a big azz cam long tubes and heads should make about the same. I've herd alot of good things about Lloyd and seeing his work on Jones's heads made the decision obvious!
