Anyone had an electric waterpump go bad?
Old Nov 1, 2003 | 08:40 AM
  #16
got_hp?'s Avatar
Originally posted by Stoopalini
Your low coolant light is most likely a faulty low coolant sensor; not really sure that has anything to do with the temp you are running at.
i have that on my car......it randomly says low coolant even though its always full.
car never went over 200* on the hottest days (florida), 170* while driving.........but it always said low coolant.
Old Nov 1, 2003 | 09:34 AM
  #17
PROJEKT Z28's Avatar
Re: Anyone had an electric waterpump go bad?
Originally posted by FastZinTennessee
....... I don't know how to test the meziere pump, is there a way?
Bring the car up to operating temp with the radiator cap off. When the coolant warms up and the thermostat opens, look into the radiator. If the pump is running properly, you will see a steady stream of coolant come out of the return line at the neck of the rad.
Old Nov 1, 2003 | 03:07 PM
  #18
TonyJ's Avatar
The thermostat doesn't have to be open to see the flow of the pump. The car can be cold and with the key on you should see the flow at the top of the radiator.
Old Nov 1, 2003 | 04:10 PM
  #19
FastZinTennessee's Avatar
Argh this is really irritating me!! I have bled this thing about 4 times....... Every time it will get hot, boil the coolant and create more air pockets in the system!!
No obstructions in the front of the radiator.
There's got to be blockage somewhere. I bought some prestone super flush, does anyone know if this stuff is any good?
Sergio
Jan 27, 2016 04:27 PM
BLK1997Z28
May 7, 2015 03:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
