Anyone EVER benefit from LT4 km ??????
Old Dec 17, 2004 | 05:57 PM
AZ2ENVY's Avatar
I have ran the LT1 km for awhile and I seen up to 9.9 degrees of knock
retard at 3/4 throttle on the scanmaster . Well i put the LT4 km in a month
ago and I have only seen 0.6 degrees of retard at WOT and that was only once. I searched and read a lot of posts from people on this board and from
what i got is that the LT4 km really doesnt help or makes knock retard
worse. Has anyone else ever benefited from the LT4 km ???? Thanks
Old Dec 17, 2004 | 05:58 PM
Pasky's Avatar
Re: Anyone EVER benefit from LT4 km ??????
Did wonders for me. But I had to run it since I went with roller rockers.
Old Dec 17, 2004 | 05:59 PM
ejfagala's Avatar
Haven't had a knock since installing mine.
Old Dec 17, 2004 | 06:48 PM
carlos64030's Avatar
I don't really know. When I did my buildup, I just automatically figured the LT4 knock module into the equation. It should be commonly known that if you install headers or roller rockers you install install the LT4 k.m.
Old Dec 17, 2004 | 07:33 PM
got_hp?'s Avatar
when i put on headers and an LT4KM and still got 7* of knock false knock......guess it doesnt work for everyone.
Old Dec 17, 2004 | 08:40 PM
TigerWoodsJr's Avatar
when my car was stock it cleared up the hesitation I had up high from the exhaust I think.
Old Dec 17, 2004 | 09:11 PM
ejfagala's Avatar
I have seen a lot of cases of false knock because the knock sensor was not properly torqued. If a KS is over TQ'ed it will be a lot more sensitive and often will cause false knock. If you add 92 octane and can rev the motor in neutral and still show a knock count odds are it is false knock and if cranked the KS in and not to the specified TQ you may have your answer.
Old Dec 17, 2004 | 09:16 PM
jeremyferguson's Avatar
I'm still getting 7-9 degrees of kr with the lt4, and it is false knock. I guess when I get it out in the spring I will check the torque.
Old Dec 17, 2004 | 09:19 PM
Josh-'04 GTO's Avatar
In my previous car (stroked/nitroused '97 WS6), I was getting a ton of false knock. LT4 KM cleared that up. Worked like a charm.
Old Dec 17, 2004 | 09:20 PM
Z95m6's Avatar
It eliminated all knock when my car was stock, i use to beable to pull a few degrees with the LT1 module. Now that i have a my new motor i get some KR everyonce in a while in summer.
Old Dec 17, 2004 | 09:22 PM
ejfagala's Avatar
You have a good chance of finding a cranked in KS and the source of your problems. Good luck
Old Dec 18, 2004 | 02:31 AM
rock1501's Avatar
When I put the stock km in I get an ses light(takes about 5 min to come on) and when I put the lt4 one in I dont so I would say it works
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
Boss002
Jul 9, 2015 03:33 PM
