Anyone care to share their tips for pacesetter install
Old Dec 11, 2004 | 12:30 AM
  #16
camzaro28's Avatar
Re: Anyone care to share their tips for pacesetter install
no i am not with revextreme.
yeha hand tools, ina driveway witha floor jack, put driver in form bottom, and paseenger in from top( took off the valve cover). all the bolts on the cats and factory y-pipe had to be broken offf cuz they were rusted on so bad. a lift and air tools , u should be able to do it in less then 8 hours. GL
Old Dec 11, 2004 | 11:54 AM
  #17
#7's Avatar
Originally Posted by Sneakin Deacon
hmm, never heard of any issue with the coating or anything burning off causing o2 problems. i bought the uncoated ones because the few people i have talked to with them complained about the factory coating saying it got bad after 6 months or so. local place by me that has a 2 year warranty on their coatings and honestly it is less than what pacesetter charges. i just worry about burning the spark plug wires
About the coating for MY pacesetters...honestly...I thought it was crap "quicky job" I dont think any prep work or cleaning was done prior to coating. I had clusters of tiny sand size blisters on areas that I did not care for at all. But mostly good,its just when things like that are present bad/crap by default IMO.
But you put them in there and really cant see those small type imprefections anyway on lower tube sections of the header so whatever I got over it
I was concerned with keeping the wires protected also with the numerous posts "burnt wires on headers" I got the 1200 degree fire sleeves they are great and looking too.
On certain boots I reused the factory metal boot protectors also call me parinoid
Talking with a guy at Thunder R. at the time of plugs wire purchase.Was saying OTV was not required.Lots get by with the factory configuration.I still opted for the OTV though.
One other thing I wanted before install,knowing that Pacesetters are a slip fit collector, was the Sure Seal sheetmetal type band clamps(found at Colemans) instead of unsing the regular type clamp they will supply.
You gonna love that sound buddy
T.
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
squarehead
Nov 21, 2014 08:02 PM
