AS&M Single Cat Conversion
Old Dec 9, 2004 | 11:41 PM
CreatiVe2's Avatar
i have read a lot on single Cat conversions and understand them, but i have really found nothing solid on 94-95 AS&M headers converted to single cat for a 97 F-body... i have my rear 02 sensors programed out in my computer, i have a SLP LM cat back (soon to be borlamouth) i understand i need an S pipe, but where should i go about getting one? and i have also heard that catco cats will work in this application, the 2.5" catco cat
Old Dec 10, 2004 | 07:12 AM
CreatiVe2's Avatar
Re: AS&M Single Cat Conversion
sorry but... TTT
Old Dec 10, 2004 | 08:02 AM
rlax31's Avatar
have you thought abuut getting the dual cat y-pipe from random tech that hooks up to them? I would understand if you didn't go that way though, they're a bit expensive
Old Dec 10, 2004 | 08:22 AM
fesgali's Avatar
SLP sells the S pipe as a kit for put the LM on to 93-95 LT1s. I tink it's like $80-$100 if i remember correctly.
Old Dec 10, 2004 | 12:05 PM
CreatiVe2's Avatar
yeah 70$... link is below... but will that bolt up to the AS&M Y pipe?
http://www.lmperformance.com/1576/2.html
Old Dec 10, 2004 | 12:38 PM
ExStyle's Avatar
ls1speed.com sells it for $30 cost me around $380 shipped for the adapter pipe and loudmouth.
Old Dec 10, 2004 | 05:00 PM
CreatiVe2's Avatar
humm not bad.. ill check it out!
Old Dec 10, 2004 | 05:36 PM
fesgali's Avatar
The ypipe bolts up to the cat, the cat will bolt up to the S pipe, and the S pipe slipfits into the catback.
I'll try and get a pic for you of the setup this weekend.
Old Dec 11, 2004 | 08:16 AM
CreatiVe2's Avatar
ok sweet... thx!!
Old Dec 11, 2004 | 09:59 AM
stereomandan's Avatar
www.thunderracing.com sells them too.
I think it was about $65 the last time I checked. Part number 99-S
Dan
Old Dec 11, 2004 | 11:03 AM
94formulabz's Avatar
I bought a mandrel bent 3" U, then had a shop cut and weld it in. It will end up costing about the same, but then you have a fully welded system and its guarenteed to fit. I'm not suggesting that parts you buy will not fit, they should work, i'm just throwing another option at you. You might also want to call summit, i believe they carry a Stainless Works s pipe that isn't listed on their website, it may be the same one thunderracing carries.
-brent
Old Dec 11, 2004 | 12:15 PM
CreatiVe2's Avatar
humm... yeah... im prob goign with the SLP LM kit.. bc i need the rubber spacer in the kit b/c the exhaust shop didnt put it on when i got the LM installed so my concern isnt the S pipe.. its getting a CAT that will fit on the end of the 3 bolt fastener on the tip of the AS&M Y pipe...
Henson071
Dec 30, 2015 09:55 PM
Aug 3, 2015 08:42 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
asilomar244
Jul 12, 2015 05:53 AM
