Anybody running a straight air filter and no intake tube?
Re: Anybody running a straight air filter and no intake tube?
Originally Posted by Critter
so if this where not a speed density car would it still be dumb?
You need to understand the genesis of the mod.... the resistor value and spoof temperature are based on the programming for the 3rd Gen engines. Richening them up helped a bit on the power end. Many of the 3rd Gens were speed-density. The LT1 programming is already way too rich. You don't want to richen the A/F mixture. Richening the mixture causes the long term fuel corrections (BLM's) to pull fuel out in closed loop. When you go WOT, the PCM defaults to "128" on the BLM"s, since it was cutting fuel in closed loop. That causes the engnie to run even richer at WOT, than the already too rich 11.7:1 target A/F ratio that stock programming usually gives you.
