anybody with the gm 847 cam ported heads and stock bottom end with auto inside please
im not sure how big that cam is but i would bet that you will need a stall conv if thats what you were wondering? I saw that you are from lafayette. How old are you? you wouldnt happen to go to Purdue would ya?
i am 30 years old and i have a stall and i already have the cam in the car i just have some surge issues and i am trying to determine if it is cam related or ignition related hope not opti where are you located do you live in the lafayette area or ?
I have quite a bit of cam surge below 2000rpm. However I have a an M6 and I'm not sure how much tuning was done in the lower RPM range. I simply keep the revs over 2000rpm when I'm cruising below 35mph where its most noticable. From what I hear, it takes a while tuning, but you can get rid of cam surge even with the GM847 cam.
LPE ...... I live in Berne..40 miles south of fort wayne. I go over to purdue every once in a while to party with one of my friends. I just wondered if you were a student...( guess not). I would bet that you are dealing with cam surge. Mine did the same thing after my cam install. Im used to it now. I just have to keep the RPMs up like the guy above does. I really doubt it is is ignition problems.
Hey Teal94z, Where you located? You know where Berne is? I go to purdue as often as i can. GREAT PARTIES. What all do you have done to your car? Id like to check it out sometime. You ever take it to the muncie dragway?
I sold my last car, it was a heads cam 1996 Formula. Ya, I have some friends that live in berne, I graduated from bellmont. I am in the process of buying another F-Bod, so hopefully soon....lata
oldschool
Feb 9, 2016 09:21 PM
