Anybody elses header do this .....
Old Dec 12, 2003 | 04:54 AM
96 WS6's Avatar
When I am changing my gasket it is a major PITA to to because the Y pipe wants to push the header so the holes don't line up. I had to pry the header back using my strut tower brace as a leverage point to line the holes up and start the bolt. Damn that sucked, and I still have one side to go! Anybody got tips on how to change the header gasket when the header doesn't want to stay put. It's funny because I bought these Percy's aluminum gasket because they had hooks on the end. Little did I know they were for the OUTSIDE bolt holes. When i saw that I was so very pissed off.
All I gotta say is if these Percy's gaskets don't fix my leak I'm gonna castrate whoever at SLP made these dual cat headers.. wish I had longtubes but what can I do
Old Dec 12, 2003 | 07:46 AM
magius231's Avatar
do yourself a favor and loosen the bolts to the Y-pipe. It will save you hours of frustration.
As far as blown gaskets,how you tighten them and how often makes a major difference in sealing. When I did mine (I'm going to put this in a text document and cut and pastse one of these days, I've done this so much ) : Tighten the header bolts. Run the car idling for ~5-10 minutes. Tighten the header bolts. Ran the car around the block, getting on it (with open headers I might add...got some stares there), tighten the bolts. Drove it for 2 hours back home (still open headers ) tightened the bolts. Then I tightened the bolts every weekend for about a month or two. Haven't loosened yet. I check them every once in a while, when I remember, but none ever come loose and I never have to worry about it much. The spark plugs, thats another story.
FWIW I used ARP stainless headers bolts, in 3/4" length. Many people have said use stage 8 locking bolts, or use 1" long bolts, but I have yet to have ANY problems and I didn't have to dink with trying to get 8 little tiny lock washers and clips on the bolts in a space that I can't even see.
edit: I used Felpro 1406 gaskets on mine too, no problems and still have the open ends.
Old Dec 12, 2003 | 12:32 PM
96 WS6's Avatar
that's what I plan to do, a 10 minute warmup, then a quick drive tightening both times. It should be good to be with aluminum gaskets after a couple tightenings. With my Felpro 1406 I tightened them literally every time I drove the car for at least a couple weeks and they still leaked badly.
So if I loosed the y pipe I would have to replace the gasket right? I don't want to mess with it since it's all sealed up.
Old Dec 12, 2003 | 09:07 PM
b-stevens's Avatar
you could also try jacking the y-pipe up, that worked for me
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
92ragtop
Dec 27, 2014 01:56 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
thenewkid
Nov 18, 2014 12:57 PM
