Any trick to changing a fuel pump?
Old May 18, 2004 | 12:46 PM
TedH's Avatar
Ok. I know I'm already over my head when the task requires anything more than using a wrench, but this looks like it should be fairly simple.
I have a hatch cut on the back deck for access. There are a few little nuts which I have removed. Now I have a few metal lines going through the round cover plate. I can pull up easily on the cover and it comes up but I think I need to remove the lines because it comes up at an angle preventing the pump from coming out... Any suggestions?
Old May 18, 2004 | 01:17 PM
Gripenfelter's Avatar
You have to disconnect the lines.
They are under the section of panel that you didn't cut towards the driver's side.
If you look through the hole you cut you will see the connection.
Old May 18, 2004 | 01:26 PM
TedH's Avatar
One even has a connecting hose. I can see where they are connected and actually get to it. Hopefully I can figure out how these things come apart. The hatch is pretty wide.
Thanks.
Old May 18, 2004 | 01:38 PM
Red96Lt1's Avatar
what he said. It's a breeze once you get those disconnected. Connecting them back up is a different story.
Old May 18, 2004 | 07:16 PM
FASTFATBOY's Avatar
The pump does not sit straight down in the hole, is towards the rear of the car. Oh and when you glue the pump back in the little deal it sits in I put the glue on and duct taped it to let it dry.
David
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
30thZ4C
Dec 26, 2014 05:09 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
