Any tips on Plug wire install
Old Apr 27, 2004 | 02:01 PM
My Red 93Z-28's Avatar
Does anyone have any tips on making my plug wire swap go smoother?
The passenger side looks like it might be a b*tch to do.
My #5 plug wire burnt on the last set-up, I guess it popped out of the bracket.
Old Apr 27, 2004 | 02:08 PM
wiked95ta's Avatar
Go to the store and get the biggest container of time and patience that they have. Maybe even two.
Old Apr 27, 2004 | 02:09 PM
haha, I have headers so maybe that will make it a little easier?
Old Apr 27, 2004 | 02:12 PM
sabre81's Avatar
remove alternator. I deleted my AC. Made everything SO much easier.
Old Apr 27, 2004 | 02:15 PM
damn, I just put my alternator back on
Old Apr 27, 2004 | 02:17 PM
97RedT/AWS-6's Avatar
If you're running your wires through the stock locations, loosen the two bolts holding the power steering. It'll give you more clearance running the wires around it. No need to take it off. And be very, very patient, it's a PITA.
Old Apr 27, 2004 | 02:38 PM
93transam1234's Avatar
when i do my wire next i am going to run the wires over the valve covers and then down beside the TB to the opti.
Ill use something to cover the wires near the TB.
Old Apr 27, 2004 | 02:49 PM
I'd recommend running them over the top too, looks like it would be much easier, but with an intercooler on one side and an FMU on the other, I'm out of luck.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
