Any Tips or Hints for Installing Racetronix Pump and Harness Kit??
Old Apr 5, 2004 | 08:23 PM
Brandon 95 Z28's Avatar
Hey,
I will be installing my racetronix high flow pump and harness kit this coming weekend and was wondering if anyone has any tips or hints for the install. Have people had sucess with installing this kit via the trap door method? I would prefer not to have to go through the hassle of dropping the tank if possible. Is the kit pretty much all plug and play, and does it come with instructions??
Thanks,
Brandon
Old Apr 5, 2004 | 09:01 PM
Jesse_Boyer's Avatar
you have access to tool to cut the rear deck and do it the easy way? If so, do it that way. The harness is cake to install. Hardest part would be dropping the tank
<------- did it this way and now that I've got to go to a twin pump setup, i'm very happy.
Old Apr 6, 2004 | 02:29 PM
Yeah, I have a dremel and some cutoff wheels. Thanks for the input. Anyone else run into any issues??
Brandon
Old Apr 6, 2004 | 03:30 PM
gost558048's Avatar
Just ordered one of those myself. Will be put in next week when it comes in.
The acess panel is very easy to cut (broke one dremel doin it, bought a new one with the flex shaft extention) very very easy :-)
Although I have one question, How do you get the assembly back IN?
(I pulled it out this morning, to discover the new assembly I had wasnt the right one). Was just going to set the old one back in to plug up the tank. I know you kinda have to rotate it once its in to get the top to line up but cant seem to do it.
Any easy ways of getting everyting set back into place?
Red96Lt1's Avatar
It doesn't come with instructions. However you can email them and they will send them to you within 10 min.
Jan 23, 2015 01:13 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
