Any need to Degree CC305
Old Mar 10, 2003 | 06:41 PM
LALT1's Avatar
Just installed CC305 and not real happy with it. Do these cams need to be degreed in? I had been told not but starting wonder. Anyone degred theres and if so how
Old Mar 10, 2003 | 06:44 PM
LALT1's Avatar
Also have had a glowing manifold affect as well. headers are on the way but they would not stop this.
Old Mar 10, 2003 | 09:13 PM
RiceETR96's Avatar
Have you got the car tunned correctly? I saw a heak of a increase in power from mine. I added all the other goodies with it too though. 30lbs injectors, twin 58mm tb, Hooker SC LT's, and RR's got a local guy to tune it and went 12.94@112.3 for a best 1/4 time, best 1/8th was 3 tenths fast than that 1/8 th mile time. a cam alone isn't going to boost you that much but with the right accessories you can gain alot. As far as the cam install goes i didn't degree mine.
Old Mar 10, 2003 | 09:18 PM
94 CAMRO Z28's Avatar
Did you get the car tuned yet? When I did my hotcam the car sucked gas, ran like crap, and was only .1 faster in the 1/4. After I got it tuned it was a night and day difference.
Aaron
Old Mar 11, 2003 | 07:09 AM
LALT1's Avatar
thanks guys. I did go with roller rockers and springs with it. as soon as I get my headers on it I will tune it and I believe I will probally be happy with it.
Old Mar 14, 2003 | 03:42 PM
LT1derful's Avatar
I would think the headers and a tune will give you the results you want. I personally don't see the stock manifold allowing that cam to exhaust fast enough...may atest for the glowing effect.
Stick in there, put those headers on, tune it and tell us what you think.
DJ
Old Mar 14, 2003 | 06:55 PM
Mindgame's Avatar
Question
Did you check the cam when you installed it? Could be way retarded which will drive the exhaust gas temps up. Seeing any knock retard??
-Mindgame
Old Mar 14, 2003 | 07:14 PM
SDAKOVIC's Avatar
I always degree all my cams. cheap insurance, easy to do and no second guessing your self.
Old Mar 14, 2003 | 08:25 PM
bad95z28's Avatar
all you need to do is line the dots straight up and down. a glowing manifold can be cause by improper valve adjustment or crossed plug wires.
Old Mar 14, 2003 | 08:50 PM
Mindgame's Avatar
I disagree.
You can line up the dots easily enough but how do you account for tolerance stacking in the timing assembly? I've seen stuff out as much as 8*.... that will cause an engine to run like a stone and you'd just be scratching your head as to why.
You check, that way you know where you're at.
-Mindgame
Old Mar 14, 2003 | 09:42 PM
Blk94Z28LT1's Avatar
glowing manifolds indicate a lean condition. Get the programming!
Old Mar 14, 2003 | 09:56 PM
Super Slow '97's Avatar
Might be a stupid ? but what is.... and how do you degree a cam.?
Because my engine is not running like I think it should. I know I need a tune but could this help also?
Matt
Mindgame's Avatar
Question
Hmmm, what happens when raw fuel burns in you headers?
-Mindgame
RUENUF
Mar 13, 2016 03:37 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
13qtr
Jul 19, 2015 05:30 PM
