Any more bolt ons/simple mods?
Old Mar 26, 2008 | 07:50 PM
showstoppers-96-Z/28's Avatar
Well, i have a 1996 Z/28 with 150k on it and the mods so far are as follows....
Engine -- K&N FIPK, Pacesetter headers, flowmaster exhaust, mild/baby cam (biggest u get from comp cams with a stock stall), 1.5 RR Arms, MadTuner PCM
Trans -- Fresh Rebuild 500 miles ago, B&M Shift Kit, 2400 Stall
Rear -- All new bearings & seals, Richmond 3.73's, M/T ET Street Tires
The thing im asking is are there anymore "simple mods" i can do (**BESIDES SWAPPING/PORTING HEADS**)? More bolt ons or mods no more difficult than as putting in new Rocker Arms, or swapping gears? I am a mechanic by trade and am fairly experienced enough to do most mods but i was wondering if anyone could suggest anymore mods that are fairly easy to get by with. I like my power level now, but more is always fun. I will eventually do the 383 but i dont have the time right now.
Anyways, if you have any ideas or opinions please voice them, thanks.
-Jon
Old Mar 26, 2008 | 07:52 PM
MeanGreen97Z's Avatar
1.6 Roller Rockers
52mmTB
TB coolant bypass
75 shot of nitrous
LCAs
PHR
SFC
weight reduction
That is what I would do.
Old Mar 26, 2008 | 07:55 PM
Originally Posted by MeanGreen97Z
1.6 Roller Rockers
LCAs
PHR
SFC
forgive me but i need clarification on what those mean, please write them out?
Old Mar 26, 2008 | 08:01 PM
dangalla's Avatar
lower control arms
panhard bar
sub frame connectors
i would do the rockers, replace the exhaust with something that actually performs and then do some suspension
2000GTP's Avatar
LCAs-lower control arms
PHR-panhard rod
SFC-subframe connectors
Old Mar 26, 2008 | 08:05 PM
thanks. i've heard the flowmaster doesnt do much and that for performance Magnaflow is the way to go so i may look into that. Suspension mods are things i havnt really thought about yet...thanks guys. Please keep em coming.
Old Mar 26, 2008 | 08:55 PM
jhthornley's Avatar
air foil ($25) - 20 minutes
TB bypass (as mentioned above) $0 - 20 minutes
Old Mar 26, 2008 | 08:59 PM
2000GTP's Avatar
The Magnaflow is a better flowing catback and should yield a small gain versus the Flowmaster. You could also do a 30 dollar exhaust cutout and probably see the same gain for less cost.
Old Mar 27, 2008 | 12:37 AM
AdioSS's Avatar
West South Central Moderator
a looser 9.5" torque converter.
What valvesprings do you have?
Old Mar 27, 2008 | 01:12 AM
LT1BanditTA95's Avatar
Could always go for a elec. water pump.. 4-5 hp give or take.You already have other small addion boltons.. Every little bit helps in my eyes. I did it and wasn't that bad.. THeres plenty of threads on the install. And yeah I'd deffantly ditch the flowmaster before any thing else... Should be easy to sell..lol
Old Mar 27, 2008 | 07:28 AM
yungin' w/a z28's Avatar
What do these mods consist of and what do they do? I've heard of them, but never had them explained properly.
Old Mar 27, 2008 | 07:46 AM
2000GTP's Avatar
The airfoil is a piece that goes into the throttle body and smooths out the incoming air charge. The throttle body has coolant lines that connect to it to help prevent the blades from icing in extreme cold conditions. With hot coolant running underneath the throttle body, it warms up the incoming air charge. The throttle body bypass disconnects those coolant lines and connects them together. This has been shown to provide a small power increase.
79RS
Mar 24, 2015 09:30 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
