Any hp advantage to a good 3 angle valvejob on stock lt1 heads?
Old Dec 1, 2007 | 07:38 PM
  #16
ZL1modified's Avatar
i have a question...
Why are they chamfered and not fillet (rounded)?
Old Dec 1, 2007 | 08:03 PM
  #17
SStrokerAce's Avatar
What the valve job?
Do you mean a radius cutter vs set angles with a hard edge?
ZL1 if you want to step up to the plate with a setup let me know.
Old Dec 1, 2007 | 08:06 PM
  #18
Originally Posted by mdacton
I got something you can test them darts on
I know and I have some waiting to get the CNC port in them right now! ;-)
Old Dec 1, 2007 | 08:21 PM
  #19
mdacton's Avatar
Originally Posted by SStrokerAce
What the valve job?
If he does not want to do it I have another car, building a bottom stock crank/rods. fresh trans and converter. full wt. street car A4 4.10
Old Dec 1, 2007 | 08:22 PM
  #20
What the valve job?
thats exactly what i mean...
I might just do that! i'll just have to hold off on the torque convertor for a while...
I'll email you monday... Do you remember me?
Old Dec 1, 2007 | 08:50 PM
  #21
Either way guys might take me a little to get them done but I'm sure they will run hard.
Bret
Old Dec 1, 2007 | 08:53 PM
  #22
mdacton's Avatar
Bret
Just need to find a good cam
Old Dec 1, 2007 | 09:10 PM
  #23
i'm in! ttyl
Old Dec 2, 2007 | 02:13 AM
  #24
rasputin's Avatar
my local engine builder did some stuff to the heads, on the invoice it says
valve job/guides/mill 250$
radius cut 100$
any idea what exactly that means, beyond it just being a "valve job?"
Old Dec 2, 2007 | 10:15 AM
  #25
NightTrain66's Avatar
Wrd1972,
yep, that is the valve job I have used for 3 yrs (since late 2004). That is when trevor Johnson starting doing my machine work. I have learned alot from that guy.
Lloyd
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
MJ_Z28
Aug 8, 2002 09:07 PM
Brian-94TA
Jul 31, 2002 02:52 PM
