Any body heard of this TB
Old Jan 2, 2007 | 09:35 AM
93z383's Avatar
Any body seen this TB. Is it just a cheap knock off or is the company just new.
http://cgi.ebay.com/ebaymotors/58mm-...QQcmdZViewItem
Old Jan 2, 2007 | 09:48 AM
Check out the review of one of their Ford intake manifolds...... appears to be low quality third-world rip-offs of other manufacturers' designs:
http://www.fordmuscle.com/archives/2...ke/index.shtml
Inspection of the Typhoon reveals the cost savings. The intake is nowhere near as cleaned up as its Edelbrock counterpart. The port openings are irregular and inconsistent in size, and there is considerable casting flash in the runners. Visually it appears the mating surfaces are square, but we wouldn't be surprised if they run wider tolerances than domestic product. Nevertheless the problems are not insurmountable. Most guys may be willing to sacrifice a couple hours of cleanup time with a die grinder for $200 in the bank. We spent a little time gasket matching the port openings (see below), and cleaning up excessive flash.
The Typhoon intake clearly needs to be gasket matched. It is obvious that the foundry does a minimal clean up of the ports and runners before shipping. This way labor costs are kept down, as are costs for sophisticated CNC machinery. This is how the intake can be priced so low. Yet this is not necessarily bad. If you are serious about power, you should be checking the port transitions on any intake, Edelbrock or otherwise. In our experience we've found that you end up gasket matching most of the time, as your head port work or milling work varies from stock.
Old Jan 2, 2007 | 12:31 PM
Greaseymec's Avatar
I saw one in a local speed shop. Looks like a low quality piece. The blades even had lots of daylight around them when fully closed. I went with the Summit 58mm TB. No issues and a satisified customer. Seems to work pretty good.
Mec
Old Jan 2, 2007 | 02:48 PM
2000GTP's Avatar
You get what you pay for. It would be unfortunate to spend the 215 bucks on that and have it turn out to be a piece of junk when you could have spent a little more to get the name brand throttle body. On a sidenote, used throttle bodies turn up in the classifieds section on this board rather frequently, you may find yourself a name brand part there for a good price.
Old Jan 2, 2007 | 03:03 PM
93z383's Avatar
Word....thats what I was leaning toward. Thougth It would be nice to have a new quality aftermarket product though...oh well
mspennyhughes
Mar 1, 2015 03:50 PM
CARiD
Feb 9, 2015 09:35 AM
edman
Jan 22, 2015 02:45 PM
squarehead
Nov 21, 2014 08:02 PM
Jay-mak
21
Oct 12, 2002 04:00 PM
