Any benefit to using 3/8" push rods?
Old May 26, 2008 | 09:11 PM
wrd1972's Avatar
Just what the title says. I currently use Comp hi-tech chromeoly .080" push rods. I have been reading that there may be gains to be had by going larger.
The benefit appears to be related to better being able to reduce valve bounce with high lift applications. Of course this would require 3/8" size guide plates which may or may not exist for LT1.
Has anyone tried this or is it a total waste of time and money?
Old May 26, 2008 | 09:16 PM
mdacton's Avatar
You running a hyd. cam? waste of time.....
You just got rid of the float so I would not want to add that wt. to it.
If you had a big *** solid roller it may be worth a little.
Old May 27, 2008 | 04:37 AM
rskrause's Avatar
Moderator
Like mdacton said, unless you are running a solid roller cam with mega spring pressures, don't give it another thought.
Rich
Old May 27, 2008 | 06:23 AM
wrd1972's Avatar
Nuff said.
Thanks guys.
Devinfoote87
Feb 12, 2016 03:21 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
