Antifreeze leak back of engine
Old Oct 1, 2009 | 06:15 AM
antman's Avatar
I just replaced the water pump and now antifreeze is leaking from the back of the engine where the transmission butts up against the engine block. Any ideas where the leak could be coming from?
Old Oct 1, 2009 | 06:37 AM
Could be coming from the steam tube connections at the back of the heads.
Old Oct 1, 2009 | 10:41 AM
turnerracing354's Avatar
It could be coming form the steam tube or it could be a freeze plug with hole, that what my 3.4 did before i swaped it
Old Oct 1, 2009 | 11:52 AM
My Red 93Z-28's Avatar
Is there any way you can get a mirror back there to look at the steam tube? That's where mine was leaking at. I pulled it off and replaced it with a spare I had and made sure the mating surface was smooth and clean, and that the special bolts were clean as well.
Old Oct 1, 2009 | 09:15 PM
OutsiderIROC-Z's Avatar
I had that issue on mine and that is what fixed it.
calaban
May 18, 2020 06:43 PM
PCLZ28
Dec 24, 2015 05:19 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
blac94Z
Nov 28, 2014 01:53 PM
