Another PROBLEM!
Old Jun 15, 2003 | 09:11 PM
blackz151's Avatar
Another PROBLEM!
damm it seems like i fix on and then get another one. Ne way this time around the problem is. The motor lags. BAD but it still goes no back fireing no poping no nuffin just a realy bad lag. it idles ok 2. It has a lil miss to it here and there but other then that fine. But the 2nd i try to go ne where i get a realy bad lag. Any idearS? Coil mabe?
Old Jun 15, 2003 | 09:50 PM
U Can't Z Me's Avatar
Do you still have a catalytic converter? Sounds like maybe that is clogged if you do.
Will the motor pull to redline?
Old Jun 16, 2003 | 12:48 AM
fbird95's Avatar
Maybe plug wires, or a dirty fuel filter. They can cause stumble.
Old Jun 16, 2003 | 01:46 AM
blackz151's Avatar
i am afriad to take it out to redline cuz i dont want the damm thing to blow up on me
lol
i havnt thought bout the fuel filter but i got a fuel psi gague moutned under the hood so ill check that 2moro
Old Jun 16, 2003 | 01:51 PM
blackz151's Avatar
it goes to redline and has normal fuel psi
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
