ANOTHER optispark problem
Old Sep 20, 2007 | 12:21 AM
95ZDOG's Avatar
I installed an accel opti spark II 2 months ago and it just died! are these any good or what?
Old Sep 20, 2007 | 06:43 AM
I haven't read much good about them.
Old Sep 20, 2007 | 08:05 AM
scottso's Avatar
Man, seems like there is no "across the board" good to say about any aftermarket brands.
Why is it so hard for them to get it right?
Old Sep 20, 2007 | 08:21 AM
Do a "search" on the Accel, and you will find way more problems than good reports.
Old Sep 20, 2007 | 12:48 PM
95ZDOG's Avatar
seems like GM is the way to go i guess,i just called summit and ordered one they are refunding my $ for the accel. I called a friend at a pontiac dealer he says there $318 with my old one I told him about thepartsladi on eBay for $230 he says to go for that. I went w/summit hopefully its worth the extra $80 just want my car back. keep up the feedback on accel . 95 stock w/ airbox and stainless borla exhaust
Old Sep 20, 2007 | 03:26 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If you ordered a GM Opti from Summit, it should be the same thing thepartsladi sells. She supposedly carries authentic AC/Delco units.
Old Sep 21, 2007 | 08:06 AM
cehan's Avatar
I too am disappointed in Accel products. I bought an Accel distributer cap and rotor for my '96 GMC Vortec engine about a month ago to replace the original cap and rotor that had 108,000 miles on them. Last Friday, while driving the truck, it just quit running like I had turned the key off! After having it towed home and spending the day troubleshooting it (and replacing the coil and ICM, even though they tested OK according to my Haynes manual), in desperation I decided to just get a new cap and rotor from Advanced Auto Parts and try that. Success! The almost new Accel cap and rotor was the problem. I don't see anything obvious, and the Accel cap and rotor has less than 1,000 miles on them, but the engine will absolutely not run when they are installed. I called Jeg's, where I bought them, and they said to send them back for a refund.
I've never heard of a cap (or rotor) failing so completely. No misfire, no stumbling, the engine just died!
Old Oct 7, 2007 | 08:55 PM
95ZDOG's Avatar
Talking another opti problem solved!
I finally installed my new GM opti and it fired right up! {with one minor problem with a loose plug that I streched out with the probe from my DVM} So the accel opti was junk but summit said they will give me a refund. I notice a leak in the rear yoke area it looks like oil is coming out between the pinion and the yoke . now that its running I gotta check that out
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
