Another Oil Pressure Post...
Old Oct 5, 2004 | 10:15 PM
S8ER95Z's Avatar
This isnt the typical oil pressure issue. When I first start my car up I see pressure up to the middle mark on my gauge. Once warmed up I see a little below the first mark on the gauge.. The pressure rises with RPM until ~3K.. then it stays steady.. about halfway between the first and the middle mark on the gauge. Even at WOT (5,000+ rpm) the guage doesnt show anything above that point. Any ideas? I just bought a new oil sending unit.. and I know you can hook a mechanical guage..but I dont think I have one available? It scares me a little.. its a 46K mile engine, and as far as I know the oil system is good.. but this does concern me. I also have the pressure drop under hard braking but I understand thats semi normal??
Old Oct 5, 2004 | 10:24 PM
fesgali's Avatar
Re: Another Oil Pressure Post...
check for intake manifold leak, i can't think of anything other then that
The mid line is about where it should be, mine shifts between a little below and right on the line, just depending on the temp.
Old Oct 5, 2004 | 10:36 PM
Pressure drop under hard braking is not normal. If the lower pressure is consistent with the drop in rpm, then that would be more normal.
Old Oct 5, 2004 | 10:40 PM
LilJayV10's Avatar
a friends car, the oil pick up tube fell off, and under hard braking it would loose oil pressure because the hole on the pump would be uncovered. It took us a while to figure it out. I'm not saying thats your problem, but it's a possibbilty.
Jason
Old Oct 5, 2004 | 10:46 PM
1 Nasty Bird's Avatar
Its been kinda cold aorund here and when cruising just after start up ive seen as high as 75 PSI according to my gauge! Warm idle is a lil over the quarter mark, and i go halfway between the half and 3/4 mark at higher rpm when warm. Your deffinatly reading low according to what im getting on my gauge.
What oil/filter are you running? Im running 5W30 castrol GTX with a delco filter. If you have an orange fram filter on your car id be looking at that as being the problem.
Old Oct 6, 2004 | 01:01 AM
S8ER95Z's Avatar
That sucks.. it was a fram filter.. TG30.. is this my problem?????
Shoe - I was low when that was happening... filled it back up and the braking issue is gone. (it was dipping but not drastically) I didnt realize that had solved the issue until just now.
Old Oct 6, 2004 | 01:05 AM
S8ER95Z's Avatar
Damn I know this is such a newbie question..but what are the symtoms to look for?? I never had this issue on my last engine..so I have no idea what to check out.
Old Oct 6, 2004 | 01:11 AM
Id get rid of that fram oil filter ASAP, they are junk and have caused more then a couple motors to blow up. STAY AWAY FROM ANYTHING ORANGE!!!! at least as far as filters go, chevy orange is still ok.
Old Oct 6, 2004 | 01:15 AM
S8ER95Z's Avatar
Hmm.searched but didnt find any info regarding that.. I have ~500 miles on the new setup..so its time for an oil change anyways.. Thanks.
Old Oct 6, 2004 | 01:43 AM
Wink Re: Another Oil Pressure Post...
http://web.camaross.com/forums/showt...m+blown+engine
check out that tread itll tell you alot about the simple oil change, and why NOT TO USE A FRAM
Old Oct 6, 2004 | 09:15 AM
S8ER95Z's Avatar
Unfortuntely there was nothing of value.. so your saying that it filters the oil better therefore is less restrictive and bad? So thats like saying a stock air filter is crap and you shouldnt run one because the K&N flows better but may allow more crap into my engine since its less restrictive. (right??) I am not even seeing anyone claim their oil pressure was affected by a fram filter..just that someone cut one apart and it had cardboard in it. Im really confused... any hard evidence?? Ill try a different brand out of curiosity and see if my pressure is affected.. if I dont see anything.. then Im not going to join in on the Fram bashing based on essentially nothing.
Old Oct 6, 2004 | 09:34 AM
High Strung's Avatar
I use Fram filters almost exclusivly and have never lost an engine because of one.
Old Oct 7, 2004 | 09:24 PM
Lonnie Pavtis's Avatar
I have read many articles about oil filters & the Fram was rated near the worst in burst strength & filtering capacity. The WIX was rated top overall in the last one that I read. If I can find the links I will post them for all to read. I have personally had 2 of them separate & blow oil everywhere & also a friend had one come apart at the seam causing a healthy leak. I quit using FRAM & now use AC due to convenience. Never had a problem with these & they can be bought almost everywhere. The WIX is available at many NAPA stores. Do an internet search on oil filter reports. Hope this helps.
Old Oct 8, 2004 | 04:56 AM
anaik's Avatar
Here's some info on filters.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
A good site on oil and filters.
http://www.bobistheoilguy.com/
Old Oct 8, 2004 | 07:52 AM
rskrause's Avatar
Moderator
I use OEM filters and have never had any problem related to them in over 40 years fooling around with cars. Spend the money on something that makes a difference, not on a fancy oil filter.
Rich
