another no start condition
Old Feb 7, 2011 | 11:41 AM
  #16
chevy_dude97's Avatar
Re: another no start condition
Originally Posted by bw_hunter
Not for the teasing bit...
If you were pulling on a ZO6 with a stock F-body, the ZO6 didn't know you were racing him....
The z06 dude missed 3rd hard,(it was his deployed friends car) I made fun of him for that...
I think he said 470hp not sure there was also a bmw cycle there the vette pulled him thru 4th then 120+ that bmw was gone, my buddy said it was the fastest production bike out right now. and that srt4 I think was having issues because 2/3 for me was ridiculous and believe it or not he blew the doors off that vette. I just talk him into racing from a dig and not 40+ rolls where he gets a little more traction
but back to the serious I can tell you I have blown up motors before and well if she let go at 6k I am pretty sure more then just the chain would have gone... I can here it has compression when I turn over the key and I hear no noise from the valve train. I guess Ill pull the cover off and check today.
Old Feb 7, 2011 | 12:23 PM
  #17
bw_hunter's Avatar
I think a few Hyabusa and Ninja zx-14 riders might disagree with the idea that a BMW I the fastest bike right now....
Good luck with the tear down.....
Old Feb 7, 2011 | 12:42 PM
  #18
ok ruled out timing chain, I pulled the cover and watched the vlvs move.... and I did a compression test on #4 and got 130psi... I guess its change out rotor time, good thing I got one of those in my garage too
Old Feb 7, 2011 | 12:51 PM
  #19
bw_hunter's Avatar
Without oil pressure you should pull the intake as well.......
  #20
oh yeah that bike is a bmw s1000rr aka the worlds fastest super bike
nothing touches it NA... period
Old Feb 7, 2011 | 12:53 PM
  #21
yeah im going with the mechanical gauge tonight when I get back from hospital. hopfully its like just below the thrreshhold of the pickup on the oil pressure sending unit because there is a ton of oil in the top end...
Old Feb 7, 2011 | 01:25 PM
  #22
rngilliland's Avatar
When my opti died the engine just cut off, like the key was turned off, at highway speed. It was due to the bearing failing, which melted the rotor. I think you have an opti problem. Since it sounds like you were running the car hard when it failed, the coolant loss could be from heat soak and possibly a bad radiator cap. I think you are worrying too much about an oil pressure problem. I would just get the car running first.
Old Feb 7, 2011 | 06:18 PM
  #23
You know there was a guy at the car show that night who was saying something like the optis can only take x rpm... blah blah he totally jinxed me...
What really irks me is I had a 97 that I put over 95k on without a single problem leaving me on the side of the road... and well I was way harder on that car plus she had allot of mods on her. I will update after opti swap...
Old Feb 9, 2011 | 02:34 AM
  #24
OK took off the opti and well Ill let the pics do the talking, there is no doubt in my mind this was the problem... jinxed I tell ya.... what a PITA to get to BTW...
Old Feb 9, 2011 | 08:07 AM
  #25
bw_hunter's Avatar
So what are you saying? Bad rotor?
Old Feb 9, 2011 | 06:05 PM
  #26
Originally Posted by Injuneer
............Do you have spark at the coil? If you have no codes for the optical sensor in the Opti, and you have no codes for the IC Module, there's a chance something happened to the rotor. You could have spark at the coil, but the rotor wouldn't be directing it to the plugs.
Dang... I finally guessed right on one......
Old Feb 9, 2011 | 06:20 PM
  #27
z0s0's Avatar
Wow. That one died hard, lol. And yes, they're fun to get to. Before I changed mine, if anyone had told me changing the distributor was a 7-10 hour job all told, I would have never believed it.
Old Feb 9, 2011 | 08:22 PM
  #28
my thoughts exactly
Old Feb 12, 2011 | 01:57 AM
  #29
YUP YUP.... full oil pressure no knocking... she purrs like the cat she is.... Blast ye OPTI ROTORS!
Ok so I had 3 optis around here one off my spare motor and one off my parts car and they both had wear on them, one had the wear from the cover flexing problem and the other had the center almost warn thru, my guess is the parts car did not run because of the opti.... and the spare motor maybe the same as everything looks rebuilt on them both...
Hey thank you for all the input and keeping me from tearing out the motor, I enjoy actually every repair as I keep learning more and more about the car.
Noenav
Mar 1, 2019 07:38 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Collector Car
Jan 5, 2015 10:58 AM
Noenav
Dec 6, 2014 07:35 PM
