another ISKY adjustable guideplate thread, with pics!
Old May 23, 2006 | 11:04 PM
Josh'95Z28conv's Avatar
Arrow another ISKY adjustable guideplate thread, with pics!
Yes, another thread
My heads have the pushrod pinch area welded up. I have crower .150" offset rocker arms for the intakes. Ive only done cylinder #1 so far.
The way I did this was to adjust as close to the intake port as I felt comfortable:
This set the rocker tip up to the valve like this:
held to the right
held to the left
I then adjusted the exhaust centered:
I dont feel comfortable with the way the intake roller tip is on the valve. Its not centered. Is this a problem? I tried the other 3 rockers after these pics, and found one that was a little closer. Weird how far off these can be from eachother.
This is what Im adjusting away from
So how far from centered is acceptable?
Old May 24, 2006 | 01:24 AM
HardcoreRM125's Avatar
Re: another ISKY adjustable guideplate thread, with pics!
I would step out on a limb and say you can have SOME variance. But FWIW, I tried to get mine all as even as I could. It takes time.
But in all honesty, I would think that you want to be less than say 1/32" off in either direction.
It's places like this where time and patience really pay off. Take your time. Do it right. And do it once. You dont want to get sloppy now with it this close to being done. I can't wait to see what your set up turns out like. Should be a real beast.
Good luck and keep us informed of how shes coming along.
Old May 24, 2006 | 06:33 AM
Jeff95TA's Avatar
Do you have any other choice? Can you clearance at the weld at all?
Old May 24, 2006 | 07:09 AM
Thats how I got them from Lloyd. Im not messing with them. Besides, their already torqued down.
Old May 24, 2006 | 06:16 PM
anyone?
Old May 24, 2006 | 08:19 PM
Dan Parker '96's Avatar
Lloyd recommended the GM guide plates to me (PN 14011051). I've read about fittment
issues with other brands. The GMs fit like a glove on every cylinder.
NOTE: The complete setup was with Comp SS NSA rockers and complementing components.
Old May 24, 2006 | 10:12 PM
I cant use GM guide plates with my setup
Old May 24, 2006 | 10:32 PM
I'm a bit baffled by your setup. If you run LE3 heads then why are you running "offset" rockers? This is new to me. Explain please.
Old May 24, 2006 | 10:36 PM
I had a little extra done to my heads
Old May 25, 2006 | 09:35 PM
anyone?
Old May 27, 2006 | 01:55 PM
SStrokerAce's Avatar
I'll look at this a little closer when I'm not trying to look at your pics on my computer thru another computer (the resolution is off). What HardcoreRM125 said is good advice just do that and you will be fine.
FWIW all the clearance you need for a pushrod from whatever it hits is about .050" clearance
Bret
Old May 27, 2006 | 01:56 PM
BTW Gary you might want to re read the part where he said he's running Crower .150 offset rockers.
Bret
Old May 28, 2006 | 08:15 PM
Well it looks like some other cylinders were even worse than this one. Im gonna have to get out my die grinder and a stone and massage me some push rod room, lol. Ill call Lloyd and see what minimum intake wall thickness he recommends. With just a little more room, I can center each one perfectly.
Old May 29, 2006 | 03:10 AM
OneFlyn95z28's Avatar
So you have the other set of heads
They are LE-X heads BTW I should know I named them After many hours of talking with Bret and Lloyd the idea was hatched and it worked!
I have had great luck with the rockers so far. I am using Jegs(Lunnati?) rockers. Originaly we thought stock rockers would work but not even close. My push rods are actually straighter then they were from the factory after all was said and done.
here are some pics
Good luck!
Old May 29, 2006 | 04:56 AM
NightTrain66's Avatar
Ellis, yours were welded up to eliminate the bad casting areas with hopes of running standard rockers and straightened that wall out pretty well. Josh's were actually done more than yours and the pushrod walls were kicked over .125 from stock and were done to "require" the .150 offset rocker.
These heads are basically a strait shot on both walls from the gasket area past the pushrod. They have the cross section of a ported TFS/AFR head. They worked good on the bench and where very quiet.
The material left in this area is all good material (as opposed to the stock "cast" area with porous material and casting lines) so you can get it pretty thin. Just make sure and mark the head where you need material removed and remove only what is needed for the PR to fit as opposed to removing matrial from the entire wall.
