Another fuel pressure question.. Does FP drop or rise when you rev?
Old Apr 18, 2003 | 09:48 PM
JasonS's Avatar
When you rev up the motor (not driving, just rev up to lets say 4000 rpm) should the FP fall or rise on our cars?
Thanks, Jason
Old Apr 19, 2003 | 12:24 AM
qwick_trip's Avatar
idling my car is at 38 psi when i rev it up then it goes to 45psi. so to answer your question it goes up.
Old Apr 19, 2003 | 01:13 AM
JasonS's Avatar
Ok lets say fuel pressure drops, What will this do and why would it drop?
It drops on my camaro from 40 to about 30
I have a Holley Adj. Fuel pressure regulator a NOS inline pump along with the stock in tank, and MSD 50 lbs/hr injectors.
Old Apr 19, 2003 | 01:32 AM
BigBlue95Z's Avatar
My experience with lowered fuel pressure is that the car will not run "up to par" so to speak and when you get up in the rpm's, it is harder to get them up any higher. And 2nd, don't know the setup in your car, but you should have more than 40psi in the 1st place.
Just my .02
Old Apr 19, 2003 | 01:37 AM
JasonS's Avatar
My car was tuned at 38 ponds static (no vacuum lines hooked up to pressure regulator) When I put the lines on it goes to about 40 # or so maybe 42 I cant remember.
But when I rev the motor the fuel Pressure drops big time. does that mean the pumps are not enough, bad injectors, lines too small?
Also from reading it looks like fuel pressure should drop when you hook up the vacuum lines. Mine goes up? Man I gotta do some more reading on this.
Any help would be appreciated guys!
Old Apr 19, 2003 | 11:55 AM
JasonS's Avatar
TTT
Old Apr 19, 2003 | 11:11 PM
96ZRDR's Avatar
Man I am having the same problem here. My car dropped 8 to 10 psi, revving w/o load, with vacumm hose connected. I replaced my filter with a new one, and now it goes down about 4 psi. My performance was restored a little, but not enough. Everyone is telling me it should be around 43 psi at WOT. I am about 8 psi off!!! I will turn up my fuel pressure tommorrow to see what is up. I still have stock fuel pump though.
Is your performance not up to par?
Old Apr 19, 2003 | 11:18 PM
Buttercup's Avatar
Fuel pressure is inversely proportional to manifold vacuum.... the more vacuum the less fuel pressure.
Rev'ing the engine is not a good indicator of fuel pressure. It would go up immediately after snapping the throttle open, go down as the vacuum stablizes, and then go down further when the throttle is closed. It should be ~43.5 psi with the vacuum removed. With a good fuel filter installed you need to place the engine under load, go WOT, and bring the revs up. It should get close to 43.5 psi. It's best to tape the fuel pressure gauge to the windshield and have a buddy watch it while you drive.
Old Apr 19, 2003 | 11:20 PM
Zpower's Avatar
i dont know if its because i have a 93 (22lb injectors) or what but i get 30psi at idle and 38-40 max at wot .
Old Apr 19, 2003 | 11:50 PM
DubbyZ28Camaro's Avatar
GM states that fuel pressure on these cars should be between 41-47 psi...they don't state whether or not that is under a load, but I would be assuming so.
Old Apr 19, 2003 | 11:54 PM
Buttercup's Avatar
Under load for two reasons.
1.) if there is any vacuum it will lower the fuel pressure. WOT=almost atmospheric/little vacuum
2.) testing with full load may uncover fuel delivery problems that may not arise with low fuel demands (ie, dying fuel pump, clogged filter, etc.)
Old Apr 20, 2003 | 12:03 AM
There you have it!!!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Nostang 96z
Sep 10, 2002 08:54 PM
