another "cooling fans won't work"
Old May 23, 2010 | 09:13 AM
95wannabe's Avatar
94 LT1/4l60e transplant into a 95Z body.
It was a compete drop-out using the 94 PCM & engine harness. The 95 body has the 3 relay config.
The fans run when I short pin 5 & 6 with key on, on the DLC.
Problem is, the fans will not run when the temp reachs 226 degrees monitored using Datamaster.
Using Tunercat, I can see the fan 1 & 2 ON threshold, low & hi mph are set stock, to 108 & 133 respectivley.
Are there any other "ECM constants" that would keep my fans from running when these temp values are reached?
Old May 23, 2010 | 09:22 AM
Do you see the fan relay flags change in Datamaster?
Old May 23, 2010 | 01:49 PM
95wannabe's Avatar
Unfortuanatley, I was in monitor mode and didn't know to look for the flag.
Now I've found it and recorded a session...don't know if this is good or bad...they're working.
I started recording once the temp came up, and sure enough, once over 108, I saw the flag go red, and the fans started. I watched it cycle 3 times...worked perfect.
I hate intermittent problems.
Thanks for the direction Shoebox
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
