another "best spark plug" thread
Old May 28, 2005 | 06:34 PM
unvc92camarors's Avatar
basically, i've got an intake and exhaust right now
looking for headers over the winter maybe, so nothing really changed from stock, engine wise
what kind do you guys like or reccommend?
i heard ngk-55s (?) are good
the ac delcos though have their pucks break off though?
also, should i just keep the stock gap?
i'm not gonna be running nitrous or anything so i'm thinking just stock gapwise
Old May 28, 2005 | 07:47 PM
Black1995Z's Avatar
Re: another "best spark plug" thread
I had never heard anyone mention this about NGK's but I dislike them because the part where the wire's boot connects to them, tend to come loose. You can actually uncrew it.
So I switched to Autolites.
Old May 28, 2005 | 09:06 PM
lt1street's Avatar
cant go wrong with AC rapid fire great plug, I have them in right now Awsome! I think Napa part number is 14.
Old May 28, 2005 | 09:08 PM
LT1-Z's Avatar
I got a question while we're on the spark plug topic. How much did you guys spend on all 8 plugs? I went to my auto parts place and they said it takes this one and only one AC Delco that cost $6.50 a plug, that's around $48 for all 8. Does that sound right? When i replaced the plugs in my '83 they only cost like 20 bucks.
Old May 28, 2005 | 09:22 PM
are the rapid fires platinum?
Old May 28, 2005 | 10:12 PM
ZMAN Z28's Avatar
They are ripping you off. It should cost about 10 dollars for Autolite 104's non platinum. If you're stock then probably go with Autolite 106's, they should be the same price. Nowhere near 48 bucks. Tell them to step away from the crack pipe.
Z
Old May 28, 2005 | 11:18 PM
NewbieWar's Avatar
i got all 8 from autozone for like 65... so 48 is a good deal i think on AC Delcos
Old May 28, 2005 | 11:40 PM
ayalam's Avatar
What would you guys use for a hotcammed ws6 with headers and all boltons no nos. Currently have tr-55 at .05.
Old May 28, 2005 | 11:51 PM
Kevin_315's Avatar
I bought bosch platnums 8 for 17$
Old May 29, 2005 | 12:09 AM
96vortechSS's Avatar
Platinum plugs aren't designed for performance. Autolites and NGK's are the best.
Old May 29, 2005 | 01:28 AM
lt1street's Avatar
Best plug is the rapid fire but they are $$$$$ i have done research on the matter calling differnt makers and stuff i work at a Napa and i have found that NGK irediens ( sorry about the spelling) and the AC rapid fire are the best for a stock internail motor and great for those nitro and turbo guys. AS for the hotcam pple i dont know, but i could feel the differents going from a tr55 to a rapid fire.
Old May 29, 2005 | 09:42 AM
96capricemgr's Avatar
The Rapidfire is MARKETTING, they are a single platinum plug that will work decent IF you get the right heat range but they will not work any better other than longevity over a TR55 or 104.
The Iridiums might be able to produce a slight bit more power since the fine electrode could allow better flame travel but that will depend on random chance as to which way it points in the chamber once installed.
If you don't mind changing plugs every 20K or so try the TR55 or 104 if you want to leave them in a long time then consider the delcos platinums or iridiums.
Old May 29, 2005 | 09:57 AM
BigJustinZ28's Avatar
I got a set of ac delco plats from napa for like 50 bucks to replace the fouled out splitfires that came with the car.
KYWes
Jun 14, 2022 06:52 AM
4586
Jul 31, 2015 06:03 PM
jackpawt883
Jul 31, 2015 08:15 AM
RX Speed Works
Jul 24, 2015 02:25 PM
pimpen1024
Jul 8, 2015 09:08 PM
