Another best LT1 head thread....
Old Jun 24, 2006 | 01:27 PM
Casey_SS's Avatar
Saw the earlier thread on this topic and thought I'd piggy back off it but narrow the field a bit....what type of head setup (brand, valve size, etc.) would you recommend for your run of the mill forged bottom end 11:1 383, HR cam custom ground to match the completed heads, ported stock intake / 58mm throttle body? Let's say total budget for heads + any porting = 4k.....
Old Jun 24, 2006 | 01:36 PM
396D1SS's Avatar
Re: Another best LT1 head thread....
visit eportworks.com and get his le3 heads and matching cam with your setup you should be over 420rwhp with more tq with a good tune
Old Jun 24, 2006 | 04:51 PM
96capricemgr's Avatar
Why the low compression?
Sounds like you aren't looking to go too wild, I would recommend talking to www.advancedinduction.com about a ported set of stock castings the whole rest of the valvetrain and maybe intake porting. Wont spend your full 4K but I don't think you are insisting on spending the whole chunk that was just the cap.
Old Jun 24, 2006 | 05:33 PM
scrmnws6's Avatar
I have jsut installed my LE2, and I cannot be more happier with the way my car runs. Just amazing, and in your budget.
Old Jun 25, 2006 | 10:29 AM
Casey_SS's Avatar
Certainly no argument against the appeal of stock heads worked over by LE or AI, but I'm a little surprised not to see Trick Flows or AFRs mentioned as discussion points. Wouldn't they be preferred candidates for feeding a 383 while staying within budget?
Old Jun 25, 2006 | 06:39 PM
The Trickflows can work very well too BUT ported LT1 castings are realisticly enough for most of us, they can feed a lot once properly opened up and for the aftermarket castings to be worthwhile you need them ported anyway.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
