aluminum drive shafts
Old Feb 23, 2003 | 10:06 PM
sc1twntrbo's Avatar
aluminum ds only come on 1le and ls1 right, someone was tryingf to tell me 96 and up came with an aluminum ds idss this right
Old Feb 23, 2003 | 10:17 PM
LPEdave's Avatar
No, they didn't. All the '93-7 LT1 f-bodies came with a steel DS, to my knowledge.
Dave
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
To the best of my knowledge that is correct but i dont think the 1LE's were aluminum, i thought they were just balanced.
Chris
Old Feb 23, 2003 | 10:23 PM
ponyackn's Avatar
The 1LE's are aluminum too. The 98's and up have the aluminum LS1 driveshafts.
Old Feb 23, 2003 | 10:26 PM
LVZ2881's Avatar
as far as I know..all 96 and up came with aluminum driveshaft.
i have one on my 97 Z28.
Old Feb 23, 2003 | 10:39 PM
LPEdave's Avatar
From the 4th gen FAQ at http://www.f-body.org/faq/4/4_1.htm#ch4_1j
Q: What's included in the 1LE performance package?
A: The package required these options (Z28/Formula, respectively):
Basic option group (FZAB/1SA)
A/C delete (until 1996 when A/C became standard)
6-speed transmission or performance rear axle with the automatic (GU5/G92)
Z-rated tires w/ 150 speedo (QLC/QLC)
Base stereo
and it consisted of:
Higher rate front springs (360 lbs/in for mid-1994 and after)
Variable rate rear springs (130-180 lbs/in for mid-1994 and after)
Stiffer front and rear shocks (Koni double adjustable for 1996 and after)
Harder bushings (front upper/lower and rear control arms)
Larger diameter anti-sway bars (32mm front, 21mm/19mm rear)
Increased cooling (for 1995 and after)
Engine oil cooler (1993 - 1995)
Stronger Transmission mount for 6 speed Transmission's
Stiffer Panhard-bar bushings
No aluminum DS listed there.
Q: What's the difference between the '95s and '96s?
A: Dual catalytic converters became standard on all Z28s, Formulas, and Trans Ams. This raised the advertised HP up to 285 from 275 for all such cars. The oil cooler (KC4) was dropped altogether. Recyclable cooper/lead bearings replace cadmium/lead bearings. Low-resistance ignition wires were designed to improve idle quality and cold-start performance. A redesigned ignition coil has half of the primary inductance as the previous coil allowing the primary current to "pour in" much quicker for much improved output at higher RPMs. Revised pistons used a new positive-twist top ring that improved the piston-to-cylinder seal and reduced blow-by emissions at high speeds. The pushrods were no longer hardened as they were in previous years. The exhaust manifolds got tri-layered stainless steel gaskets for improved durability and reduced leaks. The biggest change was that of the on-board computer. 1996 was the first year of OBD-II ECM technology to better diagnoses engine problems. This was good for reliability, but bad for some modifications in that some heavy modifications to the engine could result in a Service Engine Soon light. OBD-II also required oxygen sensors just before and after the catalytic converter for before and after measurements. Although the ones after the converter really only measure the performance of those before it.
Physically there's not much different. The exhaust tips on the Pontiacs changed from the dual-circles to single oval outlets on each side. The year brought a number of new packages. The Buick 3800 3.8L V6 was the only engine in the base Camaro and Firebird. There was also the return of the Ram-Air Pontiac (originally debuted on the late '60s GTOs). This was part of the WS6 performance package. It's just like the Firehawk except the openings on the hood are a little more forward. The package had a freer-flowing exhaust, tighter suspension (32mm front sway bar, 62 Nm front springs, 23-30 Nm variable-rate rear springs, and new valved shocks), and 17" 5-spoke wheels. HP was rated 305. SLP made the WS6 modifications at their plant after the cars left GM's factory.
Other new options included a remote, factory installed, 12-disc compact disc changer (U1S), content theft alarm requiring keyless entry (UA6), 5-spoke chrome wheels (P05). The base Firebird and Camaro models could get a sport package (Y87) with a posi rear, rear discs, 3.42 gearing in the A4, exhaust pipes/tips on both sides, and sport steering ratio. It required the 235/55 16 inch tires (QBC) though. Interior colors available on all cars were graphite, taupe (tan), and red (leather only). A new exterior color of red-orange metallic replaced medium red. As for the 1LE option, it came with A/C for the first time which was standard on all Z28s and Formulas.
No aluminum DS listed there either.
Dave
Old Mar 7, 2004 | 01:11 PM
Patrick96Z28's Avatar
My 96 came with the pos steel driveshaft(now aluminum 2000 WS6). Only 98+ comes with aluminum.
Old Mar 7, 2004 | 01:22 PM
CamaroSS30thAnn's Avatar
I read if u wer having problems with the steel diveshafts that when u took it to a dealer to have it worked on they would jut replace it with a aluminum one....not sure if it was a TSB...that might be y some of u have aluminum on ur 93-97 f-body otherwise u or someone else put it in ...i got mine off here lol
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
