Aluminum Drive Shaft
Old Jul 13, 2003 | 05:48 PM
Super Slow '97's Avatar
Well I have the high speed vibration and I was wondering if an aluminum drive shaft from an LS-1 would solve this problem. Thanks Matt
Old Jul 13, 2003 | 06:17 PM
LPEdave's Avatar
Assuming your vibration is from an unbalanced driveshaft, then most likely yes.
Dave
Old Jul 13, 2003 | 06:30 PM
jkipp84's Avatar
If you're set on getting an aluminum driveshaft, I'd at least get the stronger 1LE instead. The only ds's I've seen mentioned on here that have been twisted up are LS1's (and Injuneer's bad experience with the ACPT). It costs more, but it's by no means and expensive ds - and, of course, you get what you pay for.
Old Jul 14, 2003 | 02:32 AM
revtime's Avatar
I bought the 1LE years ago to cure my vibration and it has been good since, stronger too.
I paid around 300 or so for mine from the dealership. I was new to the LT1s and did not know there were cheaper sources than the dealer. You should be able to get it cheaper from Cromer or Dal.
Old Jul 14, 2003 | 06:01 AM
97 6SPEED Z's Avatar
Do a title search of the "LT1 Tech" forum using the title "Driveshaft Vibration Problem Solved". You may want to try what's suggested there BEFORE you buy an aluminum driveshaft?
Old Jul 14, 2003 | 07:20 AM
BKZ's Avatar
BKZ
www.dennysdriveshaft.com garenteed for life. They challenge you to break them.
Old Jul 14, 2003 | 11:16 AM
BUBBA's Avatar
I'm poised to get the 1le DS, but I don't belive that my 97SS has a vibration problem.
You can probably get your DS balanced for around $50.00. At least you'd know whether or not it is the DS that is causing the Vib before you spend the money for the Al DS. JMHO.
Please let us know if the DS cures the Vibration.
Thanks.
Old Jul 14, 2003 | 11:21 AM
Grover's Avatar
I shattered my Dynotech Engineering 6061-T6 aluminum driveshaft into 4 pieces on the first launch with the street twin. As far as Denny's driveshafts, the only ones he challenges you to break are the nitrous ready steel. He actually doesn't recommend the aluminum ones for the F-bodies.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
