Alternator electircal plug in, what is this thing called and where do you get it???
Old Mar 17, 2007 | 10:19 PM
SentimentalValue's Avatar
I broke the clip off of the electrical plug in that goes in the back of the alternator. Where do you find this electrical plug (I don't know what it's called). It's part of the wiring harness. I asked the guys at the chevy dealership and they said they don't make it anymore but said most auto parts stores should have it. So, if you've replaced it where did you get it and what is it called?
This is not the hot wire that sends the electircal current out of the alternator...
Old Mar 17, 2007 | 10:45 PM
Javier97Z28's Avatar
Moderator
I believe it's the signal pigtail for the gauge. Not positive though. You can get buy with just shoving a spade connector on the end I believe.
Old Mar 17, 2007 | 10:59 PM
GM PART # 88987962 , AC-Delco # PT494 as listed on my Tech Page. It does go to the gauge cluster, but your alternator won't charge without this wire hooked up.
Old Mar 17, 2007 | 11:11 PM
Appreciate it.
Old Mar 18, 2007 | 01:06 AM
modracr62's Avatar
Can you just supply power to it to make your alt. charge or is it more complicated than that?
Old Mar 18, 2007 | 09:50 AM
respectirocz's Avatar
i've seen replacement gm alternator pigtails at autozone, they're in the same section as headlight wiring harness replacements
just dont ask the guys behind the counter they wont know what your looking for
Old Mar 18, 2007 | 09:21 PM
As long as you add a 470 ohm resistor inline, it would work. If you run it straight to 12v, it will not (or may damage the alternator).
Old Mar 18, 2007 | 09:27 PM
mdenz3's Avatar
Or if your really determined you can find the regulators that don't require an external feed and swap it out.
and of topic a HUGE Thank you goes out to shoebox his website has helped me out alot swapping a lt1 into my thirdgen.
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HectorM52
Jan 16, 2015 10:21 AM
Hal Fisher
Sep 14, 2002 09:36 PM
