Alternator Bracket question?
Old May 31, 2005 | 02:03 PM
scubaz28's Avatar
I just put in LT Headers. Just wondering if any problem of just attaching the alternator to three bolts/brackets and not bothern with the fourth one- the one that the bracket connects to the header bolt. That one seems to be a pain getting the bracket piece in. So I tightened just the three bolts/brackets. It seems stationary enough- anyone forsee any problems?
Old May 31, 2005 | 02:22 PM
sssalah's Avatar
Re: Alternator Bracket question?
Don't think there is a problem with fixing only 3 bolts to the alt, my impy alt is only fixed on 2 bolts and its running fine so far. You can notch the header slightly yo fit the oem stud and spacer with the bottom alt brace for piece of mind.
Compstall's Avatar
Not a problem.
Old May 31, 2005 | 03:16 PM
lt11997's Avatar
I also left that bracket off after my header install. I took one look at it and said that isn't going back in, so far no problems.
HectorM52
Jun 23, 2016 08:42 PM
Noer
Feb 28, 2015 11:29 AM
HectorM52
Jan 16, 2015 10:21 AM
Hurin
Dec 13, 2014 07:38 PM
