Alt help
Old Mar 23, 2005 | 11:34 PM
blueta's Avatar
Question Alt help
Ok, I need some help figuring this out. When I wired up my LT1 with the painless harness it didn't come with anything to hook up to the alt. I got it all done except for the 4 connector clip. I know that you only need the BAT wire and the L wire connected to make it work. My problem is where do you connect the L wire to? Is it like an old GM SI type alt where the L can hook up with a simple wire to the BAT one? I have parts of the origional harness and the connecter (P L F(I) S) has 2 wires coming from it. The wires are connected to the L and the F terminal. The P is the tach signal, S is true batt voltage, and F is for the computer-sensing terminal. What the heck is the L and where does it go???
Old Mar 24, 2005 | 07:53 AM
Re: Alt help
"L" is used for the dash light on a 4th gen, but after it goes through some solid state circuitry. To make the alternator work, you can connect the "L" terminal to a 12v switched source, but add a 470 ohm resistor inline to step down the voltage. Straight 12v won't work and may harm your alternator.
The book says the "I" terminal may be used in place of the "L" and does not have to be stepped down by a resistor, though I have not heard of anyone doing this (probably because most people have the harness with only a wire coming out of the "L" cavity). Seems it should work, though.
Old Mar 24, 2005 | 12:00 PM
blueta's Avatar
Re: Alt help
I tried using the F to a 12 volt source and it didn't work... Where can you buy a resistor? Radio shack? Thanks for the help.
Old Mar 24, 2005 | 03:14 PM
Re: Alt help
RS will have a resistor.
Old Mar 24, 2005 | 03:17 PM
blueta's Avatar
Re: Alt help
Oops...I thought I posted back that I got the resistor and put it in line and everything worked out. Thanks for the help!
WPHIG2
Aug 27, 2015 06:37 AM
Gtpguy
Jan 26, 2015 04:50 PM
JDohn2001
Jul 26, 2002 05:57 PM
JDohn2001
Jul 26, 2002 08:14 AM
JDohn2001
Advanced Tech
Jul 26, 2002 12:16 AM
