I Need help installing ASP Crank & Alt Pullies!!!
Old Jul 25, 2002 | 11:21 PM
JDohn2001's Avatar
Post I Need help installing ASP Crank & Alt Pullies!!!
I have a '98 SS A4 with loudmouth, MAF ends, and whisper lid w/K&N. I recently ordered a set of the underdrive crank and alt pulleys from ASP. Before I install them I have a few questions:
1. How do I stop the crank from turning? Someone told me I might need a flywheel holder for something?
2. The directions say I need a new crank bolt. Where can I get a new one from? Does gmpartsdirect.com have it?
3. Do I need a new bolt for the alt pulley too?
4. Do I need to replace both belts or just one? The pulleys only came with one belt.
5. I am assuming that the alt pulley is replacing the pulley attached to the alternator, just to the right of the crank pulley, correct?
6. The directions say to tighten the new crank bolt to 37 ft./lbs. and then tighten an additional 120 degrees. How do I measure the 120 degrees?
Any answers are greatly appreciated.
Old Jul 26, 2002 | 12:16 AM
NOMAD's Avatar
Cool
Check this out :
RULES
Moving to LS-1 Tech
-Shannon
"Yep, getting drunk at the ol' flower shop"~ Homer Simpson
Http://nomad.cz28.com
Need to Buy stock Throttle Bodies...Email me
'95 White Z-28 T-Tops
Cold Air Intake, Ported MAF, Ported Heads, B&M shift firmer, !cat, !iat,!egr, Home Made MonoBlade, LT4 Hotcam, Cloyes, Taylor 8.5MM, Comp cams pro magnum rockers, Hooker Long Tubes, True Dual 3" exhaust, CSI Water pump, FastKitteN in the passenger seat
Best ET (Stock): 13.84
[This message has been edited by NOMAD (edited July 26, 2002).]
Chevyguy358
Jan 28, 2015 08:04 PM
Gtpguy
Jan 26, 2015 04:50 PM
Snoman73
Nov 17, 2014 07:22 PM
Geeterman
Aug 4, 2002 04:03 AM
