Alright have a 4 header choices let me know what you think???
Old Jun 15, 2004 | 02:10 PM
  #16
JoshGuitar's Avatar
I have the pacesetter shorties...they're decent. They were a little extra work (but whaddaya expect for $289?). The hole for the O2 sensor wasn't big enough, so I had to file that out some...plug access isn't too bad...equal to or better than stock manifolds. Except plug #7, if you use regular-length plugs you have to pull the header to change the plug . I used the bolts and gaskets that came with it...they don't leak at the heads. The collector/y-pipe joints leak a little, I hafta work on that. Not sure if it's actually the gaskets, or the fact that the poly-lock nuts melted and everything loosened up.
CodieG95
May 28, 2015 03:59 PM
Sauced
Apr 12, 2015 10:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
MustangEater82
19
Sep 3, 2002 02:09 PM
chiselmonkey
Aug 26, 2002 10:35 PM
