Alot of play in brake pedal?
Old Jan 28, 2003 | 04:28 PM
96z's Avatar
96z
My friend just changed the brakes on his car and there is a lot of play in the brake pedal. Anyone know what this means? I thought I knew but I forgot....
Old Jan 28, 2003 | 05:35 PM
Greasepunk's Avatar
Not enough brake fluid.
System needs to be bled.
Either one of those would probably cure the problem.
Old Jan 28, 2003 | 06:02 PM
JAFA's Avatar
when you change your brake pads you'll have less pressure on the peddle, it wiil go to the floor a few times and then the pressure will return, if for some reason it doesn't you will have to bleed the brakes.
Any other question give me a holler.
Old Jan 28, 2003 | 08:36 PM
96z's Avatar
96z
Ok, thanks Ill add some more fluid and see what happens, I have a feeling they may need to be bled....
JAFA Ill give you a holler if need be.
Old Jan 28, 2003 | 08:50 PM
WP's Avatar
WP
front or back? if their the back brakes,pull the parking brake lever a few times,this adjusts the caliper, and should be done every now and then(once a week?)
Old Jan 28, 2003 | 08:57 PM
96z's Avatar
96z
WP nope its the front brakes....
dylan1303
Aug 12, 2015 02:00 AM
mdenz3
May 22, 2015 09:25 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
