are all knock sensors the same (GM)
Old Apr 22, 2014 | 07:33 AM
77amc's Avatar
Good morning guys n gals.
I've FINALLY got around to purchase a stand alone LT1 harness for this BMW swap and with spring cleaning, "UN-burying" the bmw with all the crap I've put around it and on top of it.
SO, If I remember right one or both knock sensors were damaged when the engines were pulled.
(i've got 3 LT versions, 2-B-body {1-4.8 Caprice and 1-5.7 Roadmaster} and 1 F-body)
Can I just pull off one and screw into another block OR does it have to be side or model specific? OR even ECU specific?
Thanks E
Old Apr 22, 2014 | 07:56 AM
pizzi-man's Avatar
Re: are all knock sensors the same (GM)
It all depends on which ECM you are using. If the ecm came from a B body then you need to use 2 knock sensors if it came from a F body then use only one.
Old Apr 22, 2014 | 08:34 AM
Also depends on the year of the PCM. 93-95 F-Body LT1 use a 4500 ohm knock sensor, 96/97 LT1 used a 100,000 ohm sensor.
Courtesy of Shoebox:
1993-1995 knock sensor AC-Delco # 213-96 10456126
1996-1997 knock sensor AC-Delco # 213-325 10456287
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
