Airfoil
Old Feb 19, 2003 | 08:25 PM
landon2342's Avatar
Airfoil
Am I the only one that has problems keeping that funny looking nut inside the throttle body that holds the airfoil on. I had tried and tried again and I have no conclusion
Old Feb 19, 2003 | 08:33 PM
scoobie30th's Avatar
funny
ok, this will get some looks, when i bought my first LT1 ( a 94 Z ) it had an airfoil in it. but here is the kicker, the person whom put it in there never installed the nut. The air foil was just sitting in there, and it never moved! just passing on some info.
Old Feb 19, 2003 | 08:44 PM
RamAir95TA's Avatar
If you have an airfoil that has the small wedge that drops under the cover, make sure that it's still there and not stripped out.
Old Feb 19, 2003 | 08:51 PM
landon2342's Avatar
Your going to have to be a little more specific for me to follow but thanks for helping me. Do you think that the airfoil just sitting in there could possibly fall out and go into the elbow and just sit there and totally lose its purpose?
Old Feb 19, 2003 | 09:03 PM
RamAir95TA's Avatar
Did you install it yourself? Or was it on the car when you acquired it?
If it has a bolt through the center, it goes to a small wedge-shaped thing that you drop in through the top of the throttle body under the plate with six torx bits. Pull off the cover and see if it's stripped out (or even there). If it falls off, it won't fit through the throttle body, so you have nothing to worry about.
Bobczar
Oct 23, 2015 11:22 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Slayer
Aug 17, 2015 03:55 PM
BLK1997Z28
May 7, 2015 03:01 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
