!AIR...yes, another topic...
Old Feb 25, 2004 | 12:15 PM
AxeGrinder30thZ's Avatar
I've done a few searches on removing the AIR pump. Now, I noticed that it is benefical if you have cats, which I do not. I don't have emissions so that isn't a problem around here.
So first question...
Are there any dis-advantages to deleting the AIR when you don't have cats?
Also, when I cut my cats out, I put in o2 sims. I still got a code about a recirculation problem. Second question...Is this b/c my AIR is trying to work but I have no cats? I also have SLP headers, and I have heard people say that they can get this code when headers are installed. So I don't know.
Old Feb 25, 2004 | 12:18 PM
ppmz28's Avatar
trey, I've heard that removing your air pump and egr will set off your computer because you have the obd2. So I don't know if you should do it or not, it may not cause any problems but annoying ses light on which you already have. I removed mine and there was no prob. but I have obd1, i saw little or no gains but who knows, never threw it on the dyno.
Old Feb 25, 2004 | 12:21 PM
I know I will get a code for it, but I can get it programmed out. I don't plan to remove the EGR system. Shoebox has a great write up on his website about the EGR. Serves a pretty good purpose, so I don't plan on taking it out.
Old Feb 25, 2004 | 12:25 PM
ppmz28's Avatar
yeah i was told to remove it by several ppl so I did. no biggie
Old Feb 25, 2004 | 12:26 PM
A "recirculation" code is probably an EGR one. Has nothing to do with the AIR. Might be a backpressure issue (especially with no cats).
I don't see a problem with no AIR in your situation. Without cats, it really has little purpose.
Old Feb 25, 2004 | 12:31 PM
Hmmm...it is possible to have the "Re-circulation" code programmed out, correct? I have slp shorties,no cats, x pipe, and true dual bullets...so not much backpressure at all.
Old Feb 25, 2004 | 12:33 PM
Jim, you did block off what you needed to, right? Just makin' sure.
I see you put 52mm TB and 3.73's in your sig. You get those recently?
Old Feb 25, 2004 | 12:34 PM
The EGR code can be programmed out. So can the AIR.
macsz28
Nov 13, 2010 02:22 PM
80Scooter3.4
V6 Tech
Feb 11, 2009 06:15 PM
ukcamaroz28
May 23, 2008 07:41 AM
