Air removal questions
Old Jul 9, 2008 | 09:08 PM
TGK's Avatar
TGK
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
So I just got done removing my air pump and now my car is running like crap. I had a ses light come on a few days ago, so I got it checked and it was for the secondary air injection system. Since I was planning on removing it anyway, I went ahead and decided to pull it. After first start-up, it still threw the ses light. Then as I was backing up it went off, then came right back on.
Anyways, anyone had this problem before? Any suggestions?
*Problems fixed. Blown fuse and loose plug wires.*
Old Jul 9, 2008 | 09:46 PM
If your AIR pump blew a fuse, it would cause the SES light to come on. Removing the pump will not eliminate the SES light, unless you replace the blown fuse.
Removing the AIR pump should not cause the engine to run poorly. As I recall, the 95's that had the "AIR recall" done had a vacuum line that needs to be plugged if you remove the AIR system. Also, what did you use to plug the AIR connections in your manifolds?
Old Jul 9, 2008 | 10:32 PM
TGK's Avatar
TGK
I took the fittings to my uncle and he welded a piece of steel into the fitting to seal it. Is that ok? Also, I checked my fuses, and I had one blown. It was the only 20 fuse in the box in the engine compartment. I will be replacing it tomorrow, but does that one affect the air system in anyway. Checked my coil wire, coil harness, and MAF harness; they are all connected properly too. I will try to get under the car again tomorrow to triple check there.
Old Jul 9, 2008 | 10:49 PM
TGK's Avatar
TGK
Some other info, there was no lines running to my cat. The cat line was welded shut. Also, there was nothing running to the intake manifold.
Old Jul 9, 2008 | 11:13 PM
There are labels inside the fuse box to tell you what the fuses are for. Surely, you can tell us what fuse blew.
Old Jul 9, 2008 | 11:31 PM
TGK's Avatar
TGK
Thanks for making me feel stupid I always forget that it shows what they are on the bottom of the cover. Seriously though thank you.
Old Jul 10, 2008 | 05:21 AM
The 4th Gen cats do not have AIR lines running to them. If there is a connection on your cat for an AIR pipe, and it has been welded shut, someone installed the wrong cat, or one of the low $$$ "universal" cats available on e-Bay.
Hard to tell what "fittings" you had welded up. The usual solution is to plug the holes in the exhaust manifolds with an M22-1.5 oil drain plug. I included a thin copper washer to insure a good seal. A leak at that point will screw up the O2 sensors, and cause the engine to run excessively rich.
DirtyDaveW
Dec 1, 2016 05:37 PM
rjc1629
Jan 27, 2015 10:46 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
