lt1 ticking noise
Old Nov 17, 2010 | 03:11 PM
gforce91's Avatar
lt1 ticking noise
My lt1 is making a ticking sound, i think its coming from the top of the engine. Could it be a loose rocker arm?
Old Nov 17, 2010 | 03:18 PM
RamAir95TA's Avatar
Re: lt1 ticking noise
Sure could. Easiest thing to do would be to pop off a valve cover and take a gander.
Old Nov 17, 2010 | 04:08 PM
gforce91's Avatar
Thanks! I just took a look at the rockers one of them is loose. Now that i got the valve covers off lol should i get some 1.6 rr. Its a cc503 cam with 1.52 rockers. Would the change make a noticable difference.
Old Nov 17, 2010 | 10:54 PM
FastandBlue's Avatar
Depends on the cam, but if you change it out for something more aggressive and grab those 1.6rr, yeah, you'll notice a difference. :P
Old Nov 17, 2010 | 11:20 PM
jethrobodean's Avatar
I have to ask....How did you know it was a loose rocker? Before someone goes into a long typing rant.. I know what a loose rocker is and how to check I just want to know if the OP knows....
Old Nov 18, 2010 | 07:34 AM
bw_hunter's Avatar
It doesn't depend on the cam..every cam benefits from the different ratio as it increases duration and lift, just like a bigger cam would. You have to be certain your springs can handle the extra lift, though, before just popping them on...
Old Nov 18, 2010 | 12:38 PM
gforce91's Avatar
Its a 383 with a cc503 with ported stock heads. And my builder used 1.52rr, i just didn't know if i would benefit from 1.6rr.
Old Nov 18, 2010 | 01:02 PM
RamAir95TA's Avatar
If your springs can handle it, adding 1.6s could be worth 5-10HP.
Old Nov 19, 2010 | 01:19 PM
gforce91's Avatar
cool thanks alot. im installing them today
Old Nov 19, 2010 | 01:29 PM
bw_hunter's Avatar
Be sure to check for adequate spring clearance. you do it with a feeler gauge between the coils. You're looking for a total of at least .060" By total I mean the sum of all the clearances. 0.060" is conservative, I ws running 0.030" in a previous iteration without issues...
Fatdog2
Feb 12, 2015 12:24 PM
importkiller94
Jan 17, 2015 09:03 PM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
squarehead
Nov 21, 2014 08:02 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
