air pump recall
Old Sep 28, 2006 | 07:37 PM
deang423's Avatar
air pump recall
Can anyone tell me what the recall was on the air pump that the following web site refers to? Where does the other end of the wire (#1) go to?
thanks
http://shbox.com/1/air_pump_recall.jpg
Old Sep 28, 2006 | 07:38 PM
deang423's Avatar
Re: air pump recall
Sorry, the wire is #2, the part it plugs into is #1. I'm looking for where the other end goes....
Old Sep 29, 2006 | 01:07 PM
Re: air pump recall
The recall was specific to the 95-97 models. The AIR pump rusts up from condensate in exhaust gasses leaking back into the sytem when the AIR pump is turned off. The corrosion causes excessive power draw on the pump, and blows the fuse. They appear to be adding devices to block the passage of exhaust gasses bck into the AIR system when the AIR pump is not running (which is 99% of the time - it only runs for 2-3 minutes at startup).
Don't know where the other end of wire #2 goes. What year is your car?
Old Oct 7, 2006 | 03:49 PM
TraceZ's Avatar
Re: air pump recall
I need the bracket that holds the AIR valve vacuum solonoid in place. Judging by the diagram, it appears to attach to the front of the head. Any ideas on where I could find out more or even get a part number for the bracket?
Old Oct 7, 2006 | 07:41 PM
MachinistOne's Avatar
Re: air pump recall
What is the deal with the recall - the pump in my camaro is dead and I have a functioning replacement so I could do it myself, but I guess it will fail again at some point. Can I bring it to the dealer and make them do the fix free of charge with the updated parts because it is smog related and a recall or is this too old to have them do...I don't want to crawl under there and fix it if I can make them do it for free...
Old Oct 7, 2006 | 09:46 PM
Re: air pump recall
Call a dealer and give them your VIN to see if it still qualifies.
Old Oct 7, 2006 | 09:49 PM
Re: air pump recall
I looked, but could not find anything for you, sorry.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
